itr sway bar
Having someone else answer what sway bars YOU should use is like asking a friend to pick out a girlfriend for you...
It's what YOUR driving style prefers. Oversteer, neutral, understeer? Then not to mention the rest of your suspension setup/configuration and then tires selection/size.
There is no "fits all" here.
^^^ Agreeing with Dave ^^^
But for a recomendation, it's difficult to wrong with a decently matched set of springs/shocks and the USDM setup of 24F/22R. This works very well if you a want more aggressive setup but still streetable.
But keep in mind that you can get into trouble with it if you enjoy braking hard and turning at the same time on the street. The back will get loose if you push it to hard.
Also keep in mind that with the larger rear bar you NEED reinforcement for the rear subframe. (ASR)
I thought that the JDM fronts were 25mm, because of this link:
http://yhst-1408381693991.stores.yah...indc2tyrf.html
Not meaning to hyjack but i was wondering the same, What Sway bars should i use on my EG6? if i want to use it for road racing..
