b16a2 issues
Old Sep 15, 2009 | 04:34 PM
luispequeno's Avatar
Icon6 b16a2 issues
I recently built a new motor due to my old one spinning a rod out the side of the original block.
I bought a used JDM B16A block and put my old crank with all new bearings, pistons, rings, etc. all my bottom end is BRAND new! I had the head inspected, valves replaced and cleaned up. I then bought a re-build kit off EBAY, which included a fel-pro gasket.
so with all this said & done, i got it to crank up and couldn't ever get it to idle AT ALL when it's completely cold. I've put a new idle control valve, TPS and several other things.
When I check the codes it shows as "Engine Coolant Temperature Switch" which I have replaced and nothing has changed. I'm stomped and need some help.
Honda-tech please help me!
Thanks!
p.s. I've also had an issue with a constant oil leak. Not sure if that has any factoring with what i have going on. I've changed out the head gasket about 4 times and I end up with the same issue. Each time with me inspecting the deck and having the head re-milled. I've read that Fel-pro gaskets suck and I should be using an authentic honda head gasket. This is the only angle I took a short cut and it's costed me the most!
Am I missing somethign on the head? I have the two head guides on the block. anything else that should lay inbetween the head and block?
Inputs are welcome, thanks again!
Old Sep 17, 2009 | 03:46 PM
Default Re: b16a2 issues
any help? any advice?
Old Oct 1, 2009 | 02:59 PM
someone help please!
Old Oct 2, 2009 | 11:11 AM
somebody? anybody?
cssmith
Honda Civic (2001 - 2005)
Oct 16, 2015 01:35 PM
zimmy709
Apr 16, 2014 06:34 AM
boostedb20ek
Feb 25, 2010 03:10 AM
pentaq
Jun 17, 2009 03:21 PM
hollums2k
Nov 3, 2008 01:22 PM
