what exactly does the O2 sensor do?
Old Aug 27, 2002 | 04:34 PM
civicracer1993's Avatar
Default what exactly does the O2 sensor do?
i had mine disconnected for a while and it didnt seem to make a difference.. what does it do and do i need it connected?
Old Aug 27, 2002 | 04:56 PM
skud_dusty's Avatar
Default Re: what exactly does the O2 sensor do? (civicracer89)
it senses how much oxygen is in your exhaust. and it will probably make your engine run too rich or too lean because it senses hella oxygen. i'd keep it in if possible
Old Aug 27, 2002 | 06:50 PM
pelotudo's Avatar
You need it. It tells your ECU how you're running (Rich, lean, stoich). You will either be running really rich or really lean w/o it, and are probably throwing codes. Depening on which engine, you will also be in limp mode until you get it taken care of. If you're wondering if it has any type of "performance" gains from taking it out..it doesn't. The car will run w/o it, but you should notice a difference when you put it back in and reset your ECU.
jB
raidacaipo
Jun 7, 2008 04:24 PM
Shonn
Oct 16, 2006 04:29 AM
NuclearB18B
Nov 7, 2003 09:33 PM
ramz7887
Jul 19, 2003 10:48 AM
jdmtim
Jan 26, 2003 10:58 AM
