d16z6 question
what's a good intake to use with the d16z6 engine, i heard some people say there using a crx intake, i tried a to use 5th generation intake but i wouldn't fit
[Modified by civicsport, 2:39 AM 8/28/2002]
Hey, I have an 88 Crx Dx with a d16z6 and I have a cheap 3" short ram intake meant for a Crx Si. It fits pretty well except it does rub the battery a little bit, you may be able to avoid this by just ghetto rigging the batter and moving it up a little bit, or going all out and relocating it to the trunk. But either way I think the Si intake would probably be the best. Dont know for sure about the cold airs however.
anything that will fit over the TB and allows a filter to be attached at the other end, ALSO allowing the hood to be closed will work... [im such a ***
a filter on a tube is a filter on a tube... it dont matta
]a filter on a tube is a filter on a tube... it dont matta
