Toda flywheels
Old Aug 27, 2002 | 04:22 PM
APEX i GSR's Avatar
Default Toda flywheels
Any body with Toda flwheels ever experience any problems?
I mean problems starting the car or of the flywheel breaking?
Just curious i'm running a Toda flywheel with an ACT 6 puck disc with a heavy duty pressure plate. I am goig to get rid of it probably by the end of the year (beginning to realize Toda products aren't as good as everyone makes them out to be)
Just wanted to know if anyone else hates their Toda flywheel?
Old Aug 27, 2002 | 04:26 PM
Drag R's Avatar
Default Re: Toda flywheels (APEX i GSR)
Your the first person I've eer heard say something negative about Toda Flywheels.... Whats the problem......
Old Aug 27, 2002 | 04:30 PM
APEX i GSR's Avatar
Default Re: Toda flywheels (Top Fuel ITR)
guess i'm getting tired of the feel
part of it i know has to do with my on/off switch of a clutch now its making a funny noise which i think is due to the teeth on the flywheel not meshing with the starter teeth. I have had this set up over a year though & this is all of a sudden. I do plan on definitely getting rid of this clutch though
Old Aug 27, 2002 | 04:32 PM
non-VTEC's Avatar
i have a JDM starter for sale that will solve your starting problems with that flywheel...
Old Aug 27, 2002 | 04:35 PM
APEX i GSR's Avatar
Default Re: Toda flywheels (non-VTEC)
i haven't had a starting problem ever & the flywheel has been in for over a year
Old Aug 27, 2002 | 04:48 PM
Rembrant Q. Einstein's Avatar
I see no reason to get a chomoly flywheel now anyway, if you replace it get a Fidanza aluminum. The chromoly can only be resurfaced so many times, but you can just replace the steel friction surface (not expensive) on the Fidanza if it gets close it wearing out.
I've never heard anything bad about TODA flywheels. Odd. You can't assume and blame it on any part until you actually take it apart and see, though.
Old Aug 27, 2002 | 04:53 PM
00MRSi's Avatar
Default Re: Toda flywheels (Rembrant Q. Einstein)
maybe the Toda flywheel and ACT clutch don't work well together..
Old Aug 27, 2002 | 04:57 PM
B18CXr's Avatar
Yeah, Toda products aren't worth chit....
Old Aug 27, 2002 | 04:59 PM
neof69's Avatar
Never had a problem with my Toda FW.
Old Aug 27, 2002 | 05:03 PM
SleepyR's Avatar
New User
15,000 miles w/ no problems
Old Aug 27, 2002 | 05:53 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Toda flywheels (SleepyR)
If the FW is in decent condition I don't even need to ask do I. It'll be for Mia
Old Aug 27, 2002 | 05:56 PM
Back in Black's Avatar
Rather OG
Toda's good stuff, man. No problems with any Toda stuff that's ever graced my car.
Jason-
who's seriously thinking about H1 next year, and wants to play with his motor.
Old Aug 27, 2002 | 05:57 PM
canuckr's Avatar
Default Re: Toda flywheels (Apex i ITR)
Never had any troubles with my fylwheel.
Old Aug 27, 2002 | 06:01 PM
Apex i ITR's Avatar
Default Re: Toda flywheels (canuckr)
I can't say I haven't had a problem. I was a victim of timing belt shredding teeth and although I can't say it was the Spec B's for sure I was having problems from the time they went in.
Old Aug 27, 2002 | 07:06 PM
frogsr's Avatar
Default Re: Toda flywheels (neof69)
ditto. no problems whatsoever.
Old Aug 27, 2002 | 07:22 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Toda flywheels (frogsr)
when you sell it, contact me so I can have the same problems....
Old Aug 27, 2002 | 08:41 PM
Type R 2c's Avatar
Default Re: Toda flywheels (RealTypeR)
Toda flywheel and ACT clutch = no good
Toda flywheel and EXEDY clutch = good
Old Aug 27, 2002 | 09:04 PM
JeffNA's Avatar
DITTO ALSO
Old Aug 28, 2002 | 01:05 AM
sparkz's Avatar
Default Re: Toda flywheels (JeffNA)
https://honda-tech.com/zerothread?id=215379&page=6
Go down half way and check out my post. I am willing to bet the the insert of the flywheel and the ACT friction pads do not go together. I have a worse problem but with only 3k miles.
Old Aug 28, 2002 | 04:53 AM
IN VTEC's Avatar
After 3k miles with the Toda, I removed it during the engine overhaul and noticed that the starter gear only interacts with about 40% of the ring gear on the flywheel.
Anybody know if this is the case with stock flywheels?
I think the Toda is smaller (flatter) than teh stock units, which is the reason for the smaller interaction area.
Old Aug 28, 2002 | 04:54 AM
ITR764's Avatar
Default Re: Toda flywheels (IN VTEC)
TODA FW= best mod so far!!
Old Aug 28, 2002 | 05:01 AM
Willard's Avatar
Old Aug 28, 2002 | 05:17 AM
1GreyTeg's Avatar
No problems here.
Hell, I haven't really even heard of any problems with it from others either, which is exactly why I chose it.
BTW, did I mention that I am satisfied?
Well, I am.
A.
Old Aug 28, 2002 | 05:21 AM
Black R's Avatar
25 Year Member
.....no problems with mine, Rob Daddy!
toda = all the way (except for the price).
I'd suspect your problem is the 6puck clutch... is it unsprung?
If anything, I'd keep the flywheel and replace the clutch with something a little more "streetable," ..... maybe a full face disc (sprung hub of course)?
Old Aug 28, 2002 | 05:36 AM
Apex i ITR's Avatar
Default Re: Toda flywheels (Black R)
Its unsprung. He's kinda made up his mind about it (And the Spec B's horror story and what happened to my car just re-inforce his standpoint on it). I have another motor I'm building for Mia so if he gets rid of it I'm puting it in her motor/car.
