clutch cable ?
Old Sep 15, 2009 | 05:09 AM
kricket3000's Avatar
Icon6 clutch cable ?
i got an 88 crx hf that i'm swapping a b18a1 into, my problem is my clutch cable won't work, i can get it on the shift fork with the cable adjusted all the way out and take the bracket off and get the cable on the bracket, put the bracket back on the trans and the cable is so tight that it won't let the shift fork drop down and when i push on the pedal it won't move. do i need a cable from a DA? any idea would be great-thanks
Old Sep 15, 2009 | 11:38 AM
Default Re: clutch cable ?
Old Sep 15, 2009 | 11:41 AM
4drEF's Avatar
Keyboard Humorist
Any pics? Sounds like you are doing the rubber grommets on the cable incorrectly.
Old Sep 15, 2009 | 11:44 AM
D16SiHatch's Avatar
no you do not need a da cable. maybe there's something wrong with the clutch?
the arm is not supposed to drop back down once the cable is in place. you're supposed to tighten the cable till you can feel it start to get snug. this would indicate the throwout bearing has just begun to touch the fingers on the pressure plate. so if you cannot press the pedal down at all then either the cable is binding somehow, or the there is something wrong with the clutch assembly.
ryanevansoh
Mar 23, 2009 02:02 PM
mjfubar101
Dec 25, 2007 08:20 PM
Booz
Mar 25, 2007 06:27 PM
EKIM NART
Mar 12, 2006 06:06 PM
Verdegsr
Nov 9, 2003 07:11 AM
