B-series tranny Pro's. Help with info please!
Old Sep 14, 2009 | 11:53 PM
dragallmotor24's Avatar
Default B-series tranny Pro's. Help with info please!
My tranny says S80-3027492...What is it? Any and all help describing what it is would be appreciated. GSR,LS,etc...
Thanks
Old Sep 15, 2009 | 05:59 AM
Honda Bull's Avatar
Default Re: B-series tranny Pro's. Help with info please!
It could be LS, GSR, or JDM ITR. Have you driven on it yet?
Old Sep 15, 2009 | 06:13 AM
TurboManny's Avatar
Im with ^^^^^, but any vin tag?, but by indentifying the casing doesnt have to mean thats whats inside for gears.
Old Sep 15, 2009 | 06:29 AM
TheWickedOne's Avatar
Is the Trans out of the car or in ? If the trans is out of the car, count the # of rotations it takes on the Input shaft to make one revolution of the differential.
If you pop the trans in 3rd gear, the gear ratio of 3rd in a gsr is 1.36. X 4.40 Final. You get 5.98. you'll be turning the input shaft approx 6 times to make one revolution of the differential. Find the gear ratio calculator for hondas online for reference. When in doubt, check every gear, never know if someone has swapped out gears.
Or do it the other way .. Take trans out , crack case open and start counting teeth
Old Sep 15, 2009 | 07:39 AM
Boostfed86's Avatar
Can do the same thing as said above by raising the car and turning the crank pulley while counting axle rotation if in the car.
Old Sep 15, 2009 | 08:36 AM
With 3rd gear engaged spin the crank right? How many times do I count the axle for spinning to determine what it is.
Old Sep 15, 2009 | 08:39 AM
Yes I have.
Old Sep 15, 2009 | 09:40 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Do you know what RPM the engine is at in a given gear and given mph?
Like say 60 mph in 5th gear what RPM is the car at??
Old Sep 15, 2009 | 11:07 AM
Never driven on the street before, only race track. It went 109mph on top end of 4th gear and was at 8500rpm's...
Old Sep 15, 2009 | 11:14 AM
HamiltonRex's Avatar
small tire?
One revolution of axle = one revolution of the differential.
Old Sep 15, 2009 | 11:27 AM
tony1's Avatar
Unless the axle is broken.
Old Sep 15, 2009 | 02:32 PM
Originally Posted by HamiltonRex
small tire?
24.5x8x13 mickey thompson
Old Sep 15, 2009 | 05:49 PM
turboaap's Avatar
is there a vin plate on the trans if so what is it? not the # on the sticker.
Old Sep 16, 2009 | 12:23 AM
The one thats usually in front and green right. Dont have one. Theres the 2 holes for the tag but its not threaded for any screws.
Old Sep 16, 2009 | 01:30 AM
wolve's Avatar
109mph@8500rpm on a 24.5inch tire in 4th gear is only possible in a 6-speed K-series box.
any other gearbox it has to be aftermarket/customized
a usdm ITR with a 4.785 fd swapped in does 110mph@8000rpm, maybe your tach is way off.
same box with a 4.928 does 110mph@8200rpm, seems more likely as tachs usually are 200-300rpms off
i'd say crack it open, or drive it on the street and datalog your vss+rpm and calulate it with http://teammfactory.com/gearcalculator.php
olddohc
Transmission & Drivetrain
Oct 10, 2012 02:04 PM
weaselzz
Nov 10, 2008 06:24 PM
