help with Emission...
Old Sep 14, 2009 | 05:48 PM
honda1982's Avatar
Default help with Emission...
my 96 turbo Integra pass emission 2years ago and now it fail. I did the same thing I did 2 years ago... put back stock ecu, injectors,spark plugs, remove charge pipe,BTC is at 16*.
HC 2.04 limit is 1.2
CO 11.08 limit is 15.0
NOx 4.1 limit is 2.0
I'm thinking that my Catalytic Converter might be gone. The NOx seem to spike up under acceleration/load. The HC seem to be pretty HIGH at low speed and go DOWN to almost nothing at high speed.
Here are a few thing I'm planning to replace.
Cap and Rotor
Denso O2 sensor
Universal 3" Catalytic Converter
Oil Change
Radiator Fluid
Please Chime in if you can help...
Old Sep 14, 2009 | 05:59 PM
TunerN00b's Avatar
Default Re: help with Emission...
Well, if replacing the cat is already on the "to do" list, I think you'll need to complete those changes and see how it tests again.
Otherwise, ISO Heet or "Guaranteed to Pass" might be something to add to the gas tank to try improving those numbers. Either one will help with both HC and NOx, as they both burn cooler (NOx reduction) and cleaner (less HC) than gas.
Old Sep 15, 2009 | 11:06 AM
Janet@bisimoto's Avatar
x2
Speed_1
41
May 15, 2008 08:17 AM
bonestock91
Dec 15, 2006 07:01 PM
IshbOO
Oct 17, 2005 05:56 PM
Curtisbeef
Dec 6, 2004 01:06 PM
serious
Aug 5, 2004 09:25 AM
