crx washer nozzles
Old Sep 14, 2009 | 05:13 PM
crx_si-r's Avatar
Default crx washer nozzles
ok here is my question: how do i replace my rear window washer?
i know it sounds simple. but when i went to the junkyard to make sure it was as simple as it sounded, i noticed that the crx at the junkyard had a metal beam running along the bottom side of the roof covering the windshield washer nozzle.
Old Sep 14, 2009 | 08:45 PM
AMseven's Avatar
Default Re: crx washer nozzles
The washer nozzle itself has a small gasket and is held in by one tab on each side of it at the top (roof). The easiest way i found to take mine off was by getting a small flat bladed screwdriver and pushing in each one of the tabs at a time and slowly pry up (L/R). Be very jentle when applying pressure due to breaking the tabs. Try avoiding the gasket by sliding the flat blade over or under it. When you get it free, you should be able to pull it up and disconnect the washer fluid line
Old Sep 15, 2009 | 05:36 AM
crx_si-r's Avatar
hopefully all goes well, i will be doing it this coming weekend. but as for right now im going to re-install my SRi and my front washer nozzles.
Old Sep 15, 2009 | 12:20 PM
scottmog's Avatar
i took mine out and filled that in, removed the rear wiper and motor and filled that in also.
the washer nozzle just had two clips like hinge things just like the front ones do
siXUNE
Jul 2, 2013 07:29 AM
Projekt CR-X
Jan 17, 2011 10:13 AM
TehMoonRulz
Nov 4, 2006 09:26 PM
soulforce
Oct 2, 2005 11:48 AM
stevescivic
Jan 11, 2005 04:54 PM
