My new pro level axles
Some of you know I almost wrecked the car a few weeks ago after one of my 1st gen pro level axles broke. It scared me to death. I called up and told Lee about my problem and he said to call back and tell Frank about it. I did and before I could even finish my story, Frank said "just send them back and I will change them to the new version." How could I refuse. I dropped them off last week on our way to Englishtown for D1 and they arrived at our door today. All I can say about them is: Awesome! Now, if I only had a transmission that would hold up. I don't know how much more this stock LS can take!
looks good danny.... stupid question, the mid shaft, it passes throught the diff and there are 2 female ends on the axles?
just want to make sure im looking at that correctly.
Yeah, it comes with a spool, and since I already pro levels, the spool is still in the tranny. The intermediate shaft goes through the spool and has two female inner hubs. The left hub goes on with a snap ring and then the axle bolts to it. on the right side the hub bolts to the intermediate shaft and then the axle bolts to it.
I am still waiting on the MFactory dogbox. For now, I am using a stock LS gearbox to test a clutch. No plans on going to a small tire. I just picked up Toyo tires as a sponsor. I am goign to be using 26x9's.
those look really nice. i have had AMAZING success with my 3.9 dss axles. i do think they should recall the first batch of these and upgrade everybody to the new stuff, before any more close calls happen. see you at the shoot out, good luck
I haven't been able to make a set last more than 20 passes. I know it is mostly from the clutchless shifting setup, but the last set I was clutching it in third and fourth with a weak clutch(on purpose to try and save the gears) and the gears were still cracked. I spent so much trying to keep it together it has gotten me in the whole pretty bad. Since most of it was bad this last time, I decided to not spend any more money with them.
Sketch_hs
60
Sep 22, 2003 07:22 AM
-=TWITCH=-
16
Apr 6, 2002 09:22 PM
