integra and rsx and s2000 parts
Old Sep 14, 2009 | 04:01 PM
topshelfsd's Avatar
Default integra and rsx and s2000 parts
1. gsr rear l bracket, top tranny mount and top engine mount $80
2. gsr front subframe $40
3. obd1 gsr intake manifold bare $30
4. 99 gsr Gauge Cluster $80
5. 99 gsr 2 door side skirts oem $60
6. 99 gsr front shock forks $20
7. 99 gsr p/s line $20
8. 99 gsr main relay $20
9. 99 gsr ac pump $50
10. 98-01 clear corner lights $25
11. gsr red coupe wing $25
12. hood hinges $20
13. hood latch $20
14. bumper supports $20 each
15. oem air intake setup $60 intake arm, box and filter
16. gsr front sway bar with d brackets and bushings and endlinks $60
have bunch of miscleanous gsr parts hit me up with your needs
golden eagle black rear tow hook- san diego $60
small scrape on the bottom nothing major
Rsx Type s Garage Sale too much too list
1. 05-06 rsx type s subframe $200
2. rsx type s 5 lug spare tire $50
3. rsx type s trunk jack and tools in bag $30
4. rsx type s window regulators $80 each
5. 02-04 oem stock lip not the optional one but the stock one $25
6. 05-06 exhaust manifold and heat shield with donut $30
7. 02-04 rsx type s axle back muffler $60
8. 05-06 abs pump $50
9. rsx hood squirters $20
10. rsx windshield wipers and motor $50
11. rsx door hinges $40 per side
12. rsx black cargo cover $50
13. rsx type s rack and pinion (make offers)
14. rsx type s 5 lug rear knuckles and hubs (make offers)
15. rsx type s 05-06 front knuckles and hubs and rotors (make offers)
16. rsx type s 05-06 front and rear sway bar all complete with d brackets, bushings and endlinks
17. rsx type s rear trunk in white (broken window) $50
18. rsx type s black spark plug cover $20
19. rsx door windows $50 each
20. type s p/s axle $60
21. type s rear trailing arms (make offers)
22. rsx type s pedal assembly $60
23. rsx type s tan center console $30
24. rsx type s interior fuse box $30
25. tan rsx p/s buckle $20
26. rsx tan rear panels (make offers)
27. p/s silver rsx door 2 small dents (make offers)
28. type s hazard switch button $20
29. driver side black panel with sunrood switch and cruise and heated mirror switch $40
30. 02-04 side skirts oem $30 each
31. driver side 05-06 control arm $80
32. driver side caliper and bracket (make offers)
33. type s front and rear rotors (make offers)
34. rsx type s front brake lines and rear ones (make offers)
35. rsx type s rear ebrake cables (make offers)
1. s2000 complete rear subframe with axles, differential, all brakes, knuckles, control arms, ebrake cables, the whole shibang (make offers)
2. s2000 complete ftont subframe with rack and pinion, sway bars, knuckles, brakes, control arms , the whole shibang (make offers)
3. s2000 radiator and both fans $160
5. s2000 rear differential unit $400
6. s2000 brake booster and master cylinder $100
7. s2000 stock motor moounts (make offers)
8. s2000 stock fuel pump and sending unit (make offers)
9. s2000 rear bumper support (make offers)
10. s2000 antena mast $80
11. s2000 clutch master cylinder $75
12. s2000 ac lines (make offers)
13. s2000 heat shield in engine bay (make offerS)
14. s2000 abs pump (make offers)
Old Sep 14, 2009 | 06:22 PM
topshelfsd's Avatar
Default Re: integra and rsx and s2000 parts
bump
Old Sep 16, 2009 | 12:48 PM
SSM_EMII's Avatar
New User
I was wondering if you had the RSX muffler still for sale, if so where are you located?
Old Sep 16, 2009 | 01:00 PM
TopGear_'s Avatar
Do you have the s2000 or rsx steering wheel?
topshelfsd
Sep 14, 2009 06:59 PM
