h22 head, "mini"me" h23?
Long story short, the head on my friends h23 prelude ate its life, started pricing out parts at the local shop (pro spec Quincy, Mass) and asked about swapping the h22 Vtec head onto the h23 block and they pointed me here. My best guess is it'd be a similar procedure to a mini me D-series swap if possible which is my question. WILL IT FIT without major headache?
Easy squeazy. Search around in the prelude forums but you need to pull out an oil control orifice in the block of the H23, use all H22 timing equipment and water pump but keep the H23 manual timing tensioner, H22 head bolts and...I think thats it. H22 HG, wire up VTEC, and tune for your new found power. If you have everything apart, you might want to throw some type-s pistons in there. They drop right in on this setup, only need to make the H23 rods accept the type-s full floating wrist pins. (hmotors is the best source for these, btw)
While its all apart though you should really get everything balanced at the machine shop. Money well spent.
h22a head 93+(USDM) or 92+ (JDM) with all internals and valve cover
h22a thermostat housing
h22a waterpipe
h22a waterpump
h22a headgasket
h22a lower crank gear
h22a timing belt
h22a headbolts
h22a plug wires
h22a intake manifold (injectors perfered)
h22a header and downpipe
h22a cam gears
h22a top timing belt covers
h22a power steering braket (h23 doesn't line up right)
h22a waterpipe
h22a waterpump
h22a headgasket
h22a timing belt
h22a headbolts
h22a plug wires
h22a cam gears
awesome. thanks for the help guys. now its all about convincing my buddy to put a little more time into the motor while we have it apart. i'd give rep but im not sure where the button for it is? if you can tell me ill rep you both.
pkolaboy
Feb 19, 2008 06:37 PM
brad_prelude
Jan 4, 2005 02:02 PM
