How much does a hone take off?
Old Sep 14, 2009 | 02:29 PM
JDMEMone's Avatar
Default How much does a hone take off?
Hi there i rarely post, mostly read but i cant find the answer to this anywhere, i have a virgin B16a block that im about to build for road racing and i heard not so many good things about PCT pistons so i opted for the Japanese B16 pistons. now i wanna just freshen up the hone for the oil control. now the slugs are standard size and im gonna hone the cylinders how much will a hone take off?
Thank you guys in advance!!!
Old Sep 14, 2009 | 03:13 PM
lohatch's Avatar
Default Re: How much does a hone take off?
depends how long you run the hone up and down in the bore.
what you need to do is find someone with a bore micrometer and measure the cylinders to see if they are round and straight and find out what the existing piston-to-wall clearance is.
then you will know how much you need to take out to straighten them, or if they just need a fresh crosshatch to run those std size pistons. if they are too worn you may need to go to the next oversize
Old Sep 14, 2009 | 03:47 PM
JDMEMone's Avatar
they block has less then 50k on it i just want a fresh crosshatch, i can still see the factory crosshatch. i know omniman didn't even rehone it he just re-ringed it can cut valve releifes and called it a day.
Old Sep 14, 2009 | 04:34 PM
lohatch's Avatar
omni probably measured it though. do it right or dont do it at all. you can run a 280 or 400 grit hone through it real fast and remove .0001/2 and get your fresh crosshatch look
Old Sep 14, 2009 | 04:37 PM
egb18c5's Avatar
i doubt omniman wouldn't check it and slap in new pistons and rings, he made sure every thing was good to begin with
Old Sep 14, 2009 | 05:30 PM
JDMEMone's Avatar
well i did check it and it had about .0011 of p2w clearance and i know the walls are round, and honda recamends .002 p2w clearance. i just dont wanna take off too much while honing.
Old Sep 14, 2009 | 05:46 PM
lohatch's Avatar
well then you have almost a thou to hone out. would recommend using a 4pt hone, not a dingleberry
Old Sep 14, 2009 | 07:39 PM
JDMEMone's Avatar
i have only seen the 3 stone hone and the dingleberry, i was gonna use the 3 stone hone but where can i find fthe 4pt? and do you recamend doing it myself or having a machine shop?
Old Sep 14, 2009 | 09:11 PM
Top Ramen's Avatar
If you are worried about taking off the right amount during the hone, you really need to have a machine shop do it. If you give them the clean bare block and the pistons, its not expensive.
Old Sep 14, 2009 | 09:47 PM
jlude90's Avatar
Mine might have been $14 per hole at the machine shop. Well worth it to not have to worry about it. And after my hone I still used STD piston rings and the ring gaps all measured perfectly so i chucked the pistons in there and didn't look back. And this was a high mileage H23 block.
Old Sep 14, 2009 | 09:58 PM
ruffrhyder's Avatar
I pay $60 for a 4 cylinder block hone, jet wash and to polish my crank. Only $20 if I want it overbored any size.
Old Sep 15, 2009 | 04:16 AM
egb18c5's Avatar
honda's service limit is .002
raverx3m
Jun 10, 2014 10:55 AM
meece0927
Apr 3, 2014 06:19 AM
ludeking1007
Apr 8, 2010 09:15 AM
jakscivic
Jan 8, 2008 08:27 PM
stocker2shocker91
13
Oct 17, 2007 09:33 AM
