h22 dies after getting warmed up
Old Sep 14, 2009 | 12:24 PM
getsuummm's Avatar
Default h22 dies after getting warmed up
I have a 92 prelude with a h22a swap. Never had problems with it since the swap, about 3 years. I was driving and all of a sudden it started sputtering when I pressed on the gas and then it died. It wont start back up until it is cold. I drove it again and then let it sit in the driveway for about 15 minutes and then it died again. I replaced the spark plugs, spark plug wires, and distributor cap and rotor. I've heard it could be the coil pack, but some say they have never seen the coil pack go bad. Any suggestions would be greatly appreciated.
Old Sep 14, 2009 | 12:53 PM
Quan_97SH's Avatar
Default Re: h22 dies after getting warmed up
bad solder joint/hairline crack in some circuit board somewhere? i am guessing the heat would cause it to expand enough to cause an open and when it cool down, it would make contact again. Main relay?
Old Sep 14, 2009 | 06:38 PM
getsuummm's Avatar
I changed the coil pack. It still dies. Maybe ignition module?
Old Sep 14, 2009 | 08:52 PM
Hanmin's Avatar
with all of the money that you randomly spent on ignition parts, you could've hired a mechanic to diagnose your problem. check for spark and fuel after it is warmed up and dies. Could also be compression.
any cels?
Old Sep 14, 2009 | 10:24 PM
getsuummm's Avatar
No cels. And all that was about $100.
Old Sep 15, 2009 | 06:14 PM
Hanmin's Avatar
then check for spark and fuel after its warmed.
Old Sep 15, 2009 | 06:41 PM
jlude90's Avatar
Did you resolder the points on the main relay? This has been a problem since the 80s. Either change the main relay or resolder the contacts on the circuit board, search main relay fix or something of that nature and you'll find tons of info on it.
Old Sep 15, 2009 | 07:54 PM
RomPirate's Avatar
Maybe the IACV. might be clogged somehow. Its suppose to keep the RPMS high until warm...
Old Sep 15, 2009 | 09:23 PM
jlude90's Avatar
By his description it didn't seem like it was happening that quickly, which would rule out IACV or MAP
brian8702
Aug 19, 2010 06:43 PM
dullboy01
Nov 20, 2009 12:44 PM
BB409
Apr 30, 2009 07:11 PM
gnu1.6Si
Jun 14, 2004 05:09 PM
