91 honda accord plz help
Old Sep 14, 2009 | 12:03 PM
nyctodafullest2's Avatar
New User
Default 91 honda accord plz help
i have a 91 honda accord 2 months ago i got a new distributor and sparks. car turned on fine. now there time that the car dont wanna start it cranks and it starts when it wants to. some time i have to press on the gas a few time and u hear it like it want to turn on so i keep pressin on it up to it starts. there sometimes that it just dont wanna turn on at all. all my oil are fine. dont know what to do plz help
Old Sep 14, 2009 | 09:17 PM
bseriescrxsi's Avatar
Default Re: 91 honda accord plz help
make sure the main relay is cycling the fuel pump on(when turning key into accessory listen for a hum from the fuel pump as it will cycle on for a moment
Old Sep 15, 2009 | 07:37 PM
phootbag's Avatar
I agree. Main relay. If you don't hear a click from behind the dash when the CEL goes out ( Key on Engine off ) it's a safe bet to replace the relay. easy hour
Old Sep 15, 2009 | 08:25 PM
ShadowWorkssimc's Avatar
replace your fuel filter and as advised check the fuel pump relay, also check the fuel rails pressure is not too low.
Old Sep 15, 2009 | 08:28 PM
phootbag's Avatar
I'm all my years I have never replaced a fuel filter on a Honda due to a symptom. If a filter is plugged or restricted, look at the fuel pressure rise time, not the ending pressure. Flow will be affected.
podom
Mar 18, 2016 06:15 AM
gmeyer
Jan 24, 2013 09:50 PM
SeanaK
May 3, 2012 07:04 PM
nichole82
Mar 28, 2012 08:30 AM
91according
Mar 8, 2004 08:02 PM
