whats a good way to take out stickers on the windshield?
Old Aug 27, 2002 | 03:17 PM
LuderCriS's Avatar
Default whats a good way to take out stickers on the windshield?
coz i wanna take out some stickers thanks
Old Aug 27, 2002 | 03:26 PM
h22congee!'s Avatar
Default Re: whats a good way to take out stickers on the windshield? (chanluder)
use a razor blade , be very careful not to scratch the glass... else, use a sharp ( paint remover) plastic edge...
next, i'd either use: 1) soapy hot water OR 2) heat gun or hairdryer
to remove the sticker.
i have had lotsa successfull with option 2). heat up the sticker and tear away slowly.
-r
Old Aug 27, 2002 | 03:28 PM
95 Gizzer
Guest
Posts: n/a
Yeah if you use a hair dryer you should be able to take it right off with a rag or something
Old Aug 27, 2002 | 03:31 PM
LuderCriS's Avatar
Default Re: whats a good way to take out stickers on the windshield? (95VTECGSR)
so if i use a blow dryer i could just peel it off?
Old Aug 27, 2002 | 03:36 PM
Buckkaaaa!!'s Avatar
New User
yeah just use a hairdryer... if you still have residue left you can use goo-gone...
Old Aug 27, 2002 | 04:38 PM
714's Avatar
714
Default Re: whats a good way to take out stickers on the windshield? (preludeboy)
WD-40 takes sticker goo off no problem
Old Aug 27, 2002 | 04:56 PM
ViZ's Avatar
ViZ
Default Re: whats a good way to take out stickers on the windshield? (Zottyzot)
i used the razor many times never scratched a window
Old Aug 27, 2002 | 04:58 PM
PrecisionH23a's Avatar
Default Re: whats a good way to take out stickers on the windshield? (ViZ)
sand paper... 40 grit
[Modified by GudeH23a, 8:58 PM 8/27/2002]
Old Aug 27, 2002 | 05:13 PM
armharm's Avatar
Default Re: whats a good way to take out stickers on the windshield? (GudeH23a)
razor good.... sandpaper bad....
Old Aug 27, 2002 | 05:14 PM
LuderCriS's Avatar
Default Re: whats a good way to take out stickers on the windshield? (armharm)
lols yeah
Old Aug 27, 2002 | 07:13 PM
ichibanjap's Avatar
Rain-X takes the residue off the best, believe it or not. Everytime I need to take the shoe polish or stickers off i just use a razor. I never worry about scratches too much.
Old Aug 27, 2002 | 07:29 PM
auto-gs-king's Avatar
Default Re: whats a good way to take out stickers on the windshield? (ichibanjap)
A little trick i've learned from the detailers at my work is steel wool and windex...it takes the sticky stuff right off without scratching
portaman03
May 13, 2007 06:41 PM
jeremy.
Dec 20, 2003 03:29 AM
ebelp
Aug 21, 2002 01:01 PM
00b18b
Oct 5, 2001 05:13 PM
Steve
May 14, 2001 01:17 PM
