D16Y7 Build
Old Sep 14, 2009 | 07:01 AM
Doberio's Avatar
Default D16Y7 Build
Good morning gent's
We are running an EK in the production class of our local rally scene. We need to build our new engine within specs and I was hoping you guys could give us a hand.
Here are the rules :
- No boring/stroking
- No swap (obviously)
- Must retain stock I/M and E/M and TB (yes, all that wonderfull crappy stuff)
Basically, we're allowed to do pistons, rods and cam.
What are the best bang for the buck cam and pistons for the D16Y7.
Keep in mind that the engine will be bouncing off the rev limiters for hours on end so no 13:1 comp ratios or skyhigh power band cam.
Thank you
Old Sep 14, 2009 | 11:55 AM
Leland's Avatar
Default Re: D16Y7 Build
by far the p29 pistons! what fuel are you running? These are standard honda/acura pistons which will bump your compression up to like 13:1 +/- depending on the thickness of your headgasket. I would run e85 and a walbro pump with 310cc minimum injectors if you choose the e85 route. Wither way stock rods would suffice, but some eagle's, scat or fjt's will be better. cam route i'd call up bisi and get one of his cams, he's the man when it comes to sohc power.
Old Sep 15, 2009 | 09:32 AM
Doberio's Avatar
Thanks
I'll look into the P29's and the Bisi cam.
Old Sep 15, 2009 | 11:19 AM
Sales@Bisimoto.com's Avatar
Sent you a pm
Old Sep 15, 2009 | 01:24 PM
Leland's Avatar
what cam do you reccomend for this sort of set-up justin?
Old Sep 16, 2009 | 08:33 AM
Doberio's Avatar
Originally Posted by justin@bisimoto
Sent you a pm
Thank you Justin!
Very informative and professionnal advice.
I will talk to my team and we will discuss our plan. I will make sure to bring up the valve spring you mentionned.
Old Sep 16, 2009 | 09:03 AM
Leland's Avatar
I would love to know what your suggestions are Justin. I don't take it as you trying to sell parts, just would like to know bc I have a 14:1 e85 d16z6 with a built head but I have a zex stg.II cam in it and was wondering whether you could point me towards a better all motor cam. Leland
Old Sep 16, 2009 | 09:16 AM
Garage 808 Hatch's Avatar
Can you use stock IM's and EX from similar stock motors? The OEM Y7 mani is garbage, it has no plenum, and the stock ex manis are famous for cracking right at the O2 hole
Old Sep 16, 2009 | 09:36 AM
Originally Posted by Doberio
Thank you Justin!
Thank you for that I look forward to speaking to you in the future.
Sent you a pm
Old Sep 16, 2009 | 10:28 AM
jdmwannabee's Avatar
that's what i was thinking. even with the pistons and crazy head work and valve train upgrade that intake manifold is going to choke the life out of that motor.
Old Sep 16, 2009 | 05:44 PM
Leland's Avatar
Yea but rules are rules and it can be tuned to work properly he just wont see the full potential of the set-up until he gets some itb's or the like.
Old Sep 17, 2009 | 05:55 AM
Doberio's Avatar
Thanks, Leland, you get it !
This isn't ''drag wars'' at the Ol' air strip guys.
If it was up to us... thats the Civic we would be running and we'd take all of your cheddar:
We would'nt lose our time with the D16Y7 engine. But we are stuck with it and thats all.
Thanks for all your help.
Old Oct 7, 2009 | 02:11 PM
1986_civichatch's Avatar
beautifly done
Old Oct 7, 2009 | 04:08 PM
Leland's Avatar
sr20? lol...never seen something like that before. Is this the same platform with the y7 swapped in? Any planning done based on the advice above for the build as of yet?
Old Oct 7, 2009 | 09:46 PM
1.5Slowmatic's Avatar
id leave the stock pistons in it and mill the head head for how limited you are. Shave .04" off the head and use the cam. Than do some port work to the manifold and hopefully you can swap to a header or atleast an EX exhaust manifold. If not that try to prt the y7 piece all you can also.
Old Oct 8, 2009 | 08:21 AM
PyroProblem's Avatar
SR20 in a Honda!?
Sacrilege!
Fuel type restrictions? Can you modify the stock manifolds (porting,etc)
Old Oct 8, 2009 | 08:37 PM
riceburner700's Avatar
is head work permitted i take it?
prelude182
Apr 11, 2010 10:19 PM
Doberio
Oct 13, 2009 08:33 PM
Ding
10
Mar 22, 2006 11:35 AM
egchan
Mar 14, 2003 07:50 AM
