89 crx Si brakes on 88 dx crx
say i have come across some nice cross-drilled / slotted roters (front) for the 89 Si. my stock roters are shot......is it a bolt up as if normal maintanence deal? or id there some creativity needed. thanks..
ok, well i guess nobody knows.... umm can you tell me this...
would i be better off leaving stock brakes, but getting drilled/ slotted rotors, and some good pads, or spends way more for an all wheel disk?
[Modified by bstdvtecRx, 6:43 PM 8/28/2002]
anybody? PLEASE...my brakes are competly shot and i would like to know soon so i know what to spend the money on? thanks
if i were you, id buy plain rotors with some nice pads like ebc green. then try upgrading your master and booster to an integra's to help with braking. sense you have a 88 dx, why dont you find an si and take the rear brakes on those and put it on your car, it be a nice little set up.
the rear Si disk brakes you mean, from a 90 or 91? very hard to find around here, and are my dx rotors the same size as the Si? just curious...thank you
[Modified by bstdvtecRx, 6:53 PM 8/28/2002]
front dx and si rotors are the same size 9.5"
if you want an OEM brake upgrade get 91 4 door Civic EX rotors 10.2"
in addition to the rotors you will need calipers and knuckles
I work at Advance Auto Parts and you can get brand new EX rotors for 19.99 each
and reman calipers for 26.99each
so if you find some knuckles youll be set
note -+14" rims required
VtecSyndrome
Nov 6, 2006 02:48 PM
Serdar
Aug 14, 2005 05:35 PM
RotiEatter
10
Jul 24, 2003 12:52 PM
