OMG BEEPPPPING!!!!
So recently installed pillar mounted seatbelts and on the removal of the door mounted there was some wires wired to them. I cut the wires obviously but now at all the times my dash says the door is open and after the speedometer moves the seatbelt light both in dash and on ceiling start blinking and i also hear beeping now how do i fix this? is there a combination to the wires to make it all go away? Please help its so annoying i have to blast the radio to not hear beeping...
ok i unplugged the beeper part behind the rear view mirror. Could this also cause my brake lights to not work? Also how do you make the seatbelt light on the dash stop blinking and the doop ajar light to go off?
brake lights? check your brake bar that is attached to the place where you press your foot with. follow the bar up and there should be a small plasic tooth going through the bar. it may be chipped or broken into pieces. they cost 4 bucks at the dealer.
ok tards heres the thing i did cut them because i was in a hurry big deal but it shouldnt matter cut or unplugged either way going to have problems but anyways the point is theres a short somewhere something i did it has nothing to do with the doors thanks for being a ***** mog
