FS: Relay Boards.. Perfect for drag car or re wiring project
Old Sep 13, 2009 | 10:33 PM
RedneckRicer's Avatar
Default FS: Relay Boards.. Perfect for drag car or re wiring project
It has 5 20 amp and 5 40 amp relays. Each relay is individually fused (not included). It will work up to 16 volts. It has LED's on the inputs and outputs to indicate if the switch and relay are on or not. Hook up is simple, besides the 10 input and 10 output wires it requires only one small ground and the large 12V supply from the battery. It includes the board, mounting hardware, and ring terminals.
The board is made from 3 0z. copper. The 40 amp circuits were designed to handle much more than 40 amps with just a 10 degree C temperature rise. The 20 amp circuits are also suitably sized.
$170 Shipped + PP fee's Shipping only in the cont 48
Old Sep 15, 2009 | 02:35 PM
Default Re: FS: Relay Boards.. Perfect for drag car or re wiring project
BUMP
Old Sep 21, 2009 | 05:30 AM
Andrew Marquis's Avatar
Looks top notch! Curious to see any installed photos of it. Or of it in use in general.
GL Selling!
Old Sep 21, 2009 | 09:59 PM
sorry no installed pix. mines mounted behind my glovebox easy access for me. not very big and saves a ton of time running all the power and grounds to all the relays. or you can have most of the outputs 12v Key hot.
Old Mar 12, 2010 | 08:27 PM
iamthefollower's Avatar
Are you still selling these?? I sent you a Pm, need to know.. Really need one.
Old Mar 30, 2010 | 03:16 PM
Turbogixxer's Avatar
PMed you about these
Old Apr 10, 2010 | 05:50 PM
ucc crx's Avatar
does anyone know if he still making these?
Old Jun 10, 2010 | 12:54 PM
yes i am still making these. only to order tho.
dgerej2
Audio / Security / Video
Feb 21, 2011 05:48 AM
RedneckRicer
Sep 15, 2009 02:36 PM
RedneckRicer
Dec 29, 2008 07:01 AM
