sunroof rear drain hose
Hi I was just wondering in location of the sunroof rear drain hose and how would I clean it out? anyone can provide picture of them also if thats possible? thanks!
The car is 1990 civic hb
ok open the hatch and on the back panels where ur turn signal bubls would be there is a long clear tube but dirty by this point with a cylinder near the end of it with a whole. u can take a screw driver to it and clean the gunk out of the lines that way but get a bucket incase its got alot of water backed up.
I also recommend you back-blow the hose with compressed air to get it really clean. Fisrt open the sun roof all the way back. Next tape a dirt catcher, something like a plastic trash bag, underneath the perimiter of the sunroof hole. Use an air gun with a rubber tip to blow a bunch of air back up the drain line. You will be surprised how much dirt/trash/leaves will come flying out.
Good Luck,
Later
Good Luck,
Later
