FS: Relay Boards.. Perfect for drag car or re wiring project
Old Sep 13, 2009 | 10:31 PM
RedneckRicer's Avatar
Default FS: Relay Boards.. Perfect for drag car or re wiring project
It has 5 20 amp and 5 40 amp relays. Each relay is individually fused (not included). It will work up to 16 volts. It has LED's on the inputs and outputs to indicate if the switch and relay are on or not. Hook up is simple, besides the 10 input and 10 output wires it requires only one small ground and the large 12V supply from the battery. It includes the board, mounting hardware, and ring terminals.
The board is made from 3 0z. copper. The 40 amp circuits were designed to handle much more than 40 amps with just a 10 degree C temperature rise. The 20 amp circuits are also suitably sized.
$170 Shipped + PP fee's Shipping only in the cont 48
Old Sep 15, 2009 | 02:36 PM
Default Re: FS: Relay Boards.. Perfect for drag car or re wiring project
BUMP
dgerej2
Audio / Security / Video
Feb 21, 2011 05:48 AM
RedneckRicer
Jun 10, 2010 12:54 PM
RedneckRicer
Dec 29, 2008 07:01 AM
