Transmission & Drivetrain Gearboxes, Differentials, Clutches
1990-93 Accord Tranny question
Old Sep 13, 2009 | 03:55 PM
HondaMizzan's Avatar
Default 1990-93 Accord Tranny question
I have a 1990 Accord with a blown tranny (it's a survivor, no rust, only 100k) with the Sports option (which as I understand it was simply an option in the TCU) will there be any problems switching in a 1993 Accord tranny from a car without the Sports tranny option?
I would not imagine so, I know the casing an all that is the same, but just wanna make sure that the Sports option should still work and such.
Old Sep 13, 2009 | 04:33 PM
night's Avatar
Default Re: 1990-93 Accord Tranny question
first, define blown
Old Sep 13, 2009 | 05:50 PM
Trans will drive for about 50 yards, shifts fine, but after that it starts slipping, then it won't stay in gear, or go into a new gear. After shutting it down for a few minutes I can start it up, drive it another 50 yards, and then same thing happens.
Old Sep 13, 2009 | 08:34 PM
night's Avatar
ya, valve body stopped up/restricted and the drum is running dry.
that is def a rebuild. was just making sure as the georgia made computers die.
anyway, in the general repair work that i do that gen is just about completely identical in everything. they are very simple with only the 2 solenoid packs and a throttle cable shift control so i'd say you would be good to go with that change.
Old Sep 14, 2009 | 01:57 PM
Is this an internal valve body on these tranny's or is it something that can be removed and cleaned externally? If it's possible that I could avoid ripping the tranny out and putting in a new one that would be great.
Old Sep 14, 2009 | 09:53 PM
Mista Bone's Avatar
D Tranny Guru
Find another tranny, it's not a TH400, not serviceable without removal and complete teardown.
phantom_bcw84
Oct 2, 2010 08:04 PM
fastnite
Nov 11, 2009 11:58 AM
Taristin
Jan 5, 2005 08:24 PM
