89 civic hatch with d16a6 5 spd tran probs
i have notice that the way i shift is normal in other car but when i shift gears in this one it pull for almost every gear dunno if im shifting wrong but with other cars i shift fine no pull and i shift around 2500 to 3000 rpms any ideas on why it pulls?
second when im driving it makes a wired noise in the back like somethings spinning but with a whining noise dunno what it couldbe?
I can't understand this post at all.
What do you mean "pulls"? Does the car pull to one side under acceleration without any steering input?
If you're getting a humming/howling noise from the rear that increases in volume and pitch as the speed of the car increases, you likely have either a bad rear wheel bearing or a rear alignment issue that has caused an irregular wear pattern on the tires.
