Suspension & Brakes Theory, alignment, spring rates....
em1 suspension
Old Sep 13, 2009 | 07:52 AM
mtownsi's Avatar
Default em1 suspension
hey i reserched and couldnt find any info. will em1 suspensin bolt up to a 93 4dr. im looking to to a rear disk conversion n wondering if its a posible and what i need to make it work
Old Sep 13, 2009 | 09:40 AM
STOCK_SOHC_DX's Avatar
Default Re: em1 suspension
This has been covered a 1000000000 times. EK suspension will not bolt up to EG!
Old Sep 13, 2009 | 01:28 PM
pb16b's Avatar
Yes, the EM1 rear disc conversion will bolt right up to your EG.
Old Sep 14, 2009 | 08:58 AM
mtownsi's Avatar
thanks now would it be the whole trailing arm that will bolt up ?
Old Sep 14, 2009 | 05:16 PM
batallic's Avatar
yea, i think u need the lcas since the ek's are longer
Old Sep 14, 2009 | 10:31 PM
Not a suspension item but you will need integra 4dr hand brake cables.
Old Sep 15, 2009 | 06:19 AM
phunhaus's Avatar
Just use the trailing arms and ebrake cables. Everything else will be from your EG suspension.
Old Sep 15, 2009 | 08:40 AM
mtownsi's Avatar
ok thanks every1
Old Sep 15, 2009 | 08:54 AM
mtownsi's Avatar
o also im gunna be swaping the front rotors and calipers from my em1 to my 93 lx will i need to use the em1 proportioning valve? and to swap the front brakes all i have to do is swap the calipers,rotors,bracket n pads roght?
hondaOchibi7
Mar 9, 2011 10:23 AM
neophyte210
Nov 2, 2005 08:07 PM
92 CIVIC HATCH VX
Nov 29, 2004 06:21 PM
NoLipRacen
Jul 7, 2003 05:05 PM
