B16 bogging
Old Sep 12, 2009 | 05:56 PM
powerpro_69's Avatar
Default B16 bogging
Just got done with my build amd went to take the car out if u give it too much gas it bogs way done the it will go after a sec or 2 fuel pump filter plugs wires are all new car is timed
any ideas would be nice
Old Sep 12, 2009 | 09:37 PM
spoonfedcrx's Avatar
Default Re: B16 bogging
what ecu? i had a PR3 swapped B16 and i had to swap O2 sensor wires at the ecu. cleared it right up.
Old Sep 13, 2009 | 03:52 PM
i did an obd1 harness to a chipped ecu from pherable.net and a new obd1 dizzy
Old Sep 16, 2009 | 02:45 PM
check engine light?
Old Sep 18, 2009 | 07:45 PM
no check lights fuel pressure is good
Old Sep 23, 2009 | 06:27 PM
Clur's Avatar
Did you find a solution? if so post it.. I had same issue and was a pain in the **** to resolve due to incomplete threads.. some ppl find an answer and don't share it.. also I wanted to know some more info on your situation.. my problem was on a 97 civic using a obd1 engine with obd1 conversion harness.. turned out I put wrong injectors.. but im wondering on yours.. my freind is using a odb 0 - 1 on his DA w/ a gsr swap.. i've changed injectors and looked over wiring.. it still bogs bad.. but when he uses his odb 0 harness ( ls ) it runs fine???
Old Sep 23, 2009 | 08:27 PM
no i havent fixed it yet drove it today and it pops code 21 so ill have to check that out
its a b16a1 obdo converted to obd1
Old Sep 24, 2009 | 07:21 PM
cleaned the screen and checked out the valve and its good
Turboredteg
15
Oct 14, 2011 03:06 PM
BoostinTEG
Engine Management and Tuning
15
Sep 3, 2011 08:15 AM
tsr2
14
Dec 2, 2006 10:23 AM
Turbo88hatch
May 17, 2005 06:54 PM
Mark
Oct 23, 2003 08:33 PM
