y8 header on a b7 block
Old Sep 12, 2009 | 03:27 PM
Diller's Avatar
Default y8 header on a b7 block
I'm trying to get my b7 running a little better untill I finish building my y8. Right now the car has a short air ram, 2.25 exhaust and test pipe, advanced the timing a bit and set the lift on the valve a little higher then stock. I have the stock b7 header on right now. I what to know if I change to the stock y8 header, will it have any gains or will my bottom end suffer? I'm not sure if there is any difference between them. I don't think there is anyway to mod the exhaust, Right? I know if there are any gains they will be minimal but every little bit helps. I was also thinking of putting on a fpr but I don't know if that would have any effect on it right now.
Also will a y8 oil pan fit on a b7? mine has a small leak.
Old Sep 12, 2009 | 04:51 PM
Autointeg's Avatar
Default Re: y8 header on a b7 block
it will flow much better, non vtec has 4-1 exhaust manifolds and vtec sohc's have 4-2-1 upgrade ur intake manifold also will make it flow much better, not sure about oil pans :S lol
Old Sep 12, 2009 | 05:27 PM
Diller's Avatar
Thank you very much. That's all I needed to know.
hkboy87
Jul 3, 2007 08:30 AM
kamakaze1
Nov 2, 2005 05:36 PM
f1uxx
May 28, 2003 12:31 PM
BlackCRX
Sep 2, 2002 02:04 PM
