Parasitic door open sensor
Old Sep 12, 2009 | 10:04 AM
Danthemagicbum's Avatar
Default Parasitic door open sensor
my cousins ef battery is draining constantly when car is off. someone said the door open sensor is draining it when the door is closed. i found the sensor can i cut it? or what do i do with it?
Old Sep 13, 2009 | 09:10 AM
Default Re: Parasitic door open sensor
bump
Old Sep 13, 2009 | 09:16 AM
johnnyonth3spot's Avatar
Is the seatbelt light going off, indicating that a door is open when its really closed this is important. I had this problem you may have to adjust them if this is the case. I had to shim the inside plastic clip and move it out because the plastic had worn.
Old Sep 13, 2009 | 02:09 PM
JOE BD-0's Avatar
Don't cut it, it may short out. Just unplug it and the plastic will insulate the wire end from shorting against the inside of the door. Good luck.
Old Sep 13, 2009 | 04:17 PM
It is 'tnot the seat belt sensor because we unplugged those
Might have figured out the problem with Rick Rabies help.
If its not the starter ground i will bump later.
blackdoutrsx
24
May 31, 2010 09:07 AM
SoCalCrX.com
Mar 22, 2008 06:30 AM
uniquelylost
Jul 27, 2007 11:10 AM
Cyber ITR
Jan 18, 2004 01:23 AM
