my clutch making a squeeking sound.
I don't know if this is normal squeeking sound from clutch.
Everytime I press the clutch, I hear squeeking sound from clutch,
Sound like the spring is the making noise.
I just want to find out, see if this is normal sound before I take my car to the dealer...
^^ same here. My buddy applied Grease to something, I cant think of what the parts called and it stopped his on his Scion. Mine makes a Pop noise when the clutch pedal gets close to being fully pressed in.
Road House
My old car did this for about 4 years. If its just a squeek when you compress the pedal its no big deal, i never had any clutch problems beside the squeek. If it bothers you, lube it up
A lot of ep's have this problem, look behind your clutch pedal (top) and apply some white lithium grease to that rod. Work the clutch a few times, spray again, and repeat until noise goes away. Some people get rid of it by doing a clutch pedal adjustment but that might cause some detrimental effects so don't do it unless you 100% understand what you are doing.
thats how mine was, its been raining for the past 4 days and it wouldnt stop for anything and it was when i would be releasing the clutch.
but now it hasnt rained in a while and its not making the noise anymore.
