Ignition coil wire
i need to know which wire and color and location at the dizzy harness or engine harness and cabin harness, only for the ignition coil power wire, i need this wire for my WOT BOX, almost the same thing as an MSD 2 step, i need to split this wire and add the one wire goin towards the cabin and the other goin towards the engine, anyone know which wire this is let me know thanx
what i meant is i have something like an MSD with 2 step but its called a WOT BOX and it says i have to cut the wire for the ignition coil and add one wire from the wot box from the one end of the coil wire, and the other wot box wire to the other end to complete the connection of the coil through the wot box, but its tellin me to cut the black/yellow wire but which one and where? it says ignition coil power?
ok so theres the think black/yellow wire at the dizzy that runs to the driversside firewall, and then theres the black/yellow wire at the ECU which is thin but still has voltage which i think is pin 25 on connector A so it would be A25 which is IGP2 power source
fastludeh22
Apr 21, 2003 05:26 PM
