91 crx hf
Old Sep 11, 2009 | 04:53 PM
hughes si's Avatar
Default 91 crx hf
The Good:
B16a Swap
Short Ram Intake
Short Throw Shifter
Koni Adjustable Coil Overs, and Struts
OBD1 Jumper Harness
P72 ECU
HA Sport Motor Mounts, & Linkage
3" Straight Pipe
No Name Header
Mint Condition CRX SI Seats
Rear Drums Converted Over To Disc (with type r master cylinder, and proportioning valve)
Projector Headlights, With Halo Rings
No Rust
Fully Gutted, Ready For Racing
14" Steelies(not the prettiest but there light, and have good tires)
ALL NEW:
Plugs
Plug Wires
Distributor Cap & Button
Water Pump
Timing Belt
Valve Cover Gasket
Oil Pan Gasket
Needs:
Cam Seal ($15 on eBay)
The Starter Rebuilt (Can roll start, it will crank right up sometimes)
Car Is Really Low To The Ground(may want to raise it, depending on what you want the car for)
Side Moldings Were Shaved & Needs To Be ReBondo In Spots
Old Sep 14, 2009 | 06:51 AM
PS122's Avatar
Default Re: 91 crx hf
bump - for looking
hamtrow
Aug 11, 2019 10:21 AM
hutcho3
Dec 29, 2010 07:23 AM
SFlCrx
Jan 20, 2009 03:45 PM
TYPEcRx
Dec 10, 2007 02:58 PM
kantfadedisazn
Sep 27, 2006 06:52 PM
