B20's whats the difference?
Old Sep 11, 2009 | 02:34 PM
turbodcxbro's Avatar
Icon2 B20's whats the difference?
Sorry if its been posted but I've searched and can't seem to find it. I see that there is a B20b and B20z. From what I can tell the B20z makes more hp is this correct? I want to swap my wifes tired LS motor in the 94 teg for a nice clean stock B20. Wheres the best place to find a low mileage motor and what kinda cost am I looking at?
Old Sep 11, 2009 | 04:57 PM
audiobahncrazy's Avatar
Default Re: B20's whats the difference?
b20z has more compression
Old Sep 11, 2009 | 05:17 PM
So thats it? Heads are the same?
I have the option of buying a fully worked LS head with Skunk2 valve train and Crower cams in it as well as a nice port and polish job, would this head bolt on and work better than the stock B20 head?
Old Sep 12, 2009 | 01:08 AM
Ruben19's Avatar
b20z has knock sensor
Old Sep 12, 2009 | 03:23 AM
.Manny.'s Avatar
Touching My Member
the LS head will bolt right up to the b20. I would recommend that you tune the car if you are using more aggressive cams
Old Sep 12, 2009 | 07:37 AM
unusual71's Avatar
http://www.automotivehelper.com/topic550033.htm
Old Sep 12, 2009 | 07:51 AM
redsolturbo's Avatar
be careful of P2v on a z motor.
Old Sep 12, 2009 | 02:02 PM
Care to elaborate a lil more man? I'm a noob to Hondas and have no idea what the P2V is?? Sounds like the code for the head?
Thanks for the help guys!
Old Sep 12, 2009 | 02:11 PM
ALLxMOTOR EG's Avatar
Vietnamese!
http://www.nonvtec.com/forums/b20-no...fe431f1320b7c7
Old Sep 12, 2009 | 02:28 PM
Originally Posted by unusual71
Great link! Thanks Unusual!
Old Sep 12, 2009 | 02:40 PM
xander1100's Avatar
you can find b20s for really cheap on the hondamarketplace and on ebay.
Old Sep 13, 2009 | 02:23 PM
p2v = piston to valve.
should be ok using oem valves/head, jsut clay it if you run larger lift or duration cams, or increase the valve size
Old Sep 13, 2009 | 02:35 PM
gutted-dx's Avatar
They'll be marked on the ends.
Old Sep 13, 2009 | 04:32 PM
p2v- gotcha! I will clay it anyway just for assurance.
I'm not sure which crower cams are in the head, supposed to talk to the guy here soon and take a look at it.
Old Sep 13, 2009 | 07:40 PM
gutted-dx's Avatar
They should be marked on the Distrbutor side.
SCIVIC94
Mar 3, 2005 06:57 PM
Reservation-Sensation
Jan 7, 2005 06:48 PM
JDMike_DB8R
Dec 14, 2004 07:35 AM
justa4door
Feb 10, 2004 07:42 AM
