5lug conversion question?
so i put the rsx 5 lug conversion on. control arms and all. and set the car back down on the tires and the wheels were almost touching the rear of the fender...
could this be bc the control arm(s) are bent or what?
ill will attach pics to explain.
left aint as bad as the rt
this is a stupid question but are you sure you either dont have the control arms reversed/flipped? there should be a little tab that comes off the rear of each control arm for an antisway bar. my bet is they are flipped on the wrong sides.
lemme know after you check.
nah good check but no the arms can only go one way into the sub frame...and i hav the sway bar and everything hooked up and ready to go...thats why i am stumped...
i was thinking maybe trying to use the em2 arms on the rsx hub...idk it that wld either work or mate up...you know? :/
i just switched my em2 arms to rsx ones that i had energy suspensions bushings pressed into. they can be installed upside down if you have the sides switched (driver on pass. side) and the sway bar would still bolt up so check and look carefully.
BWRSUPPORT
36
Oct 14, 2013 01:57 PM
