92 integra LS wont start (no power)
Old Sep 11, 2009 | 12:59 PM
DynastyRacer22's Avatar
Default 92 integra LS wont start (no power)
i got a 92 integra LS and theres no power at all not even at the dome light, i replaced the battery and tested everything there is power at the battery and at the fuses..but the car wont start at all..no dash light will light up at all..ive search on google and on HT but couldnt find any info but from what ive read it says somethin about the ignition switch or the ecu can be bad? im not quit sure if someone can help me id apreciate it thanks!
Old Sep 11, 2009 | 01:10 PM
Dcinno's Avatar
Default Re: 92 integra LS wont start (no power)
maybe ecu sounds like my problem
Old Sep 11, 2009 | 01:30 PM
did you have the same problem before? ive checked every single fuse in the car and also replaced the battery 80amp fuse and still nothing..
Old Sep 11, 2009 | 05:57 PM
ls_vtec_da's Avatar
might be a loose wire if you have a tester test the battery clamp wires its possible that it might be shorted or something else might be shorted.
Old Sep 11, 2009 | 07:01 PM
yeah i tested all that and theres power but im not sure why theres nno interior light..i went to the kent junkyard called budget auto wrecking and i bought the wrong ecu for it it was a 37820-pr4-a02 and the number below it is 430-127049 AC
Old Sep 13, 2009 | 05:35 PM
ls_vtec_da's Avatar
pr4 is LS next check the ignition switch by the key ignition check if everything is ok.
GPC91
May 23, 2013 09:15 AM
hate!
Apr 21, 2013 08:04 AM
anewman1234
Jun 14, 2011 07:10 PM
SilenceinShadows
Sep 28, 2010 04:01 PM
Goldenls
Apr 8, 2010 11:09 PM
