NJ:****~GARAGE SALE CHEAP~**** ~~PARTS ADDED 9/10 9/14~~
Old Sep 11, 2009 | 12:22 PM
Arct's Avatar
Default NJ: Many OEM and Aftermarket parts Cheap! UPDATED
*ALL OEM SENSORS FROM A 1997 GS-R *
81,xxx ALL PERFECT WORKING CONDITION
TELL ME WHAT YOU NEED!
ARP b16 & b18c5 Main studs
never torqued down hand tightened in my block until i realized they where the wrong item took them out and put them back in the box, Nuts and washers have never been open.
$70.00
Hondata Intake Manifold Gasket b18b b18a b18c5 head
never mounted
$45.00
Stock GS-R Flywheel
110.xxx Miles
$20
OEM Honda MAP sensor
Brand new never installed
$55.00
OEM Intake Air Temperature Sensor
$45.00
Two 97 GS-R Exhaust Manifolds
81,xxx Miles one 110,xxx on the other
Mint Condition for a stock exhaust manifold No Dents/scrapes
$30 Each
97 GS-R Air condition
Works fine, everything from firewall forward.
$120.00
*we can discuss prices if you want parts from it.
Megan Racing 3" high flow cat
Never opened
$40.00
OEM 97 GS-R Shifter
Mint Condition
$15.00
97 OBD2 GS-R Intake Manifold
81,xxx Miles I can include used sensors with each
$50 each
OEM 97 GS-R Air Intake Arm with Filter
81,xxx Miles
$10.00
97 Gsr Starter
81,xxx Miles Works perfect
$60.00
97 GS-R Crank Pulley with bolt
81,xxx Miles
$25.00
97 GS-R Water Pump
20,xxx Miles
$25.00
97 GS-R Pistons Rings and rods and rod bolts
81,xxx Miles Mint Condition
$40.00
Name is George. Hit me up @ 6099705219 Call or text. I'm sure we can work something out. If you want pictures just let me know and ill get back 2 you.
Old Sep 11, 2009 | 05:08 PM
Arct's Avatar
Default Re: NJ:****~GARAGE SALE CHEAP~****
bump
Old Sep 11, 2009 | 06:49 PM
Go n 4 10s's Avatar
Dibbies on the shifter
Old Sep 12, 2009 | 04:42 AM
Arct's Avatar
bump
Old Sep 12, 2009 | 06:37 AM
Arct's Avatar
bump
Old Sep 12, 2009 | 06:59 PM
Arct's Avatar
Default Re: NJ:****~GARAGE SALE CHEAP~**** ~~PARTS ADDED~~
bump
Old Sep 13, 2009 | 08:10 AM
Arct's Avatar
bump
Old Sep 13, 2009 | 05:22 PM
Arct's Avatar
bump
Old Sep 14, 2009 | 06:08 PM
Arct's Avatar
bump
Old Sep 14, 2009 | 06:28 PM
direct_connect's Avatar
i know someone called dibs on it but still got the shifter? maybe they backed out? but my brother needs one.
Old Sep 14, 2009 | 07:28 PM
Arct's Avatar
Default Re: NJ:****~GARAGE SALE CHEAP~**** ~~PARTS ADDED 9/10 9/14~~
bump
Old Sep 14, 2009 | 09:17 PM
Arct's Avatar
bump
Old Sep 15, 2009 | 08:33 AM
Arct's Avatar
bump
Old Sep 15, 2009 | 09:51 AM
EJ8kid's Avatar
i think i bought another shifter off you...i had the green da on advans... good dude bump!
Old Sep 16, 2009 | 07:41 PM
Arct's Avatar
bump
Old Sep 16, 2009 | 09:11 PM
kennybintegra's Avatar
where in jersey you located. need that starter
Old Sep 17, 2009 | 03:05 AM
Arct's Avatar
bump
Old Sep 17, 2009 | 10:43 AM
Arct's Avatar
bump
Old Sep 19, 2009 | 07:28 AM
Arct's Avatar
bump
Old Sep 19, 2009 | 02:07 PM
Arct's Avatar
bump
Old Sep 20, 2009 | 02:47 PM
Arct's Avatar
bump
Old Oct 31, 2009 | 07:39 AM
Arct's Avatar
bump
Old Oct 31, 2009 | 07:03 PM
Arct's Avatar
bump
Old Nov 1, 2009 | 06:13 AM
B18PwdCivic's Avatar
bumppp for a good seller
Old Nov 1, 2009 | 10:15 AM
Arct's Avatar
bump
