Chicago/NWI - Custom D series EF turbo kit
May fit other Civics, it was built for EF and there are some parts IE the front crossmember/traction bar that are EF only.
I have a custom turbo setup for an EF chassis with D series.
Greddy TD04h turbo internal wastegate
Greddy cast turbo manifold
FULL 3" exhaust from turbo to rear bumper, downpipe wrapped
Custom intake pipe with 3" K&N filter, bolts to open location in front pass side of engine bay, might or might not work with stock battery location...?
Custom charge tubing and all silicone couplers and T clamps
Custom FMIC w/ backdoor inlet
Oil lines
Evo 560 injectors
boost/vac gauge
Oil pressure gauge
Everything you need to boost your d series EF hatch is here. EVERYTHING. I can even sell you a chipped ecu, if you want to go obd1 I've got harness. If it's necessary and not listed, I've got it.
All T bolted tubing with good couplers
Custom dp and charge
IC fits behind unmodded bumper
I will not separate the above. For exhaust clearance a custom or aftermarket front crossmember is required. I have one for $250 if you buy the turbo kit
If I can find it I'll include a turboxs manual boost controller.
$1250 pick up only
That's a deal... The crossmember and exhaust/chargepiping cost me $1k, the turbo kit started out as a new Greddy kit (1400) $125 for the IC, Whatever for the gauges, $50?, $200 for injectors, $50 for the K&N, $20 for header wrap, $80 for oil lines... plus a ton of stuff I'm not thinking of I'm sure, I've got almost 3k in this setup. Could you do it cheaper than 3k, yes. Can you do it cheaper than 1250? Hell no.
I've also got a Turbosmart 38mm external wastegate
$110 shipped
Oil lines
Evo 560 injectors
boost/vac gauge
Oil pressure gauge
$1250 pick up only
$110 shipped
danmdevries
Oct 13, 2009 01:01 PM
danmdevries
Dec 1, 2008 01:59 PM
danmdevries
Nov 3, 2008 05:21 PM
