FL FS/FT: 2002 GTI 350whp CCW's
FOR SALE: $11,000 takes it
this car is my daily driver, has cold a/c and power steering.
2002.5
103k
awp 20v 1.8t
motor/big turbo setup
t3/t04e 50trim .63 360 thrust bearing
atp hardware
unitronic 630 software
tial 38mm wastegate
tial 50mm bov
ghl 3'' exhaust with turndown tip/muffler
IE rods
new rod bearings
all new gaskets on the top half, head gasket, valve cover gasket, etc.
brand new timing belt @ 92k
brand new metal impeller water pump @ 92k
oem 1.8t hybrid oil pan
greedy 28r fmic with custom 2.5'' piping (hidden behind bumper like eurojet)
greedy profec b spec 2 electronic boost control (low boost/high boost)
blitz turbo timer (locks car when it turns off)
fully clean engine bay including full wire tuck.(just needs filler and paint to have a "shaved bay")
transmission
5 speed
peliquin LSD
raxxle super axles (lifetime warranty)
10lbs autotech flywheel
vr6 clutch
diesel geek short shifter
maintenance
brand new 20th/gli front rotors @ 99k
brand new 20th gli front carriers @ 99k
brand new mintex red box brake pads @ 99k
brand new cabin filter @ 100k
brand new brake master cylinder @ 103k
brand new rear driver side caliper @ 103k
exterior
reflex silver
fresh respray on the front end
filled hood notch
filled bumper notch
shaved side markers
shaved hatch
rear euro bumper
oem 20th headlights
oem passenger side stubby mirror
interior
oem 20th steering wheel
oem r32 full leather heated seats (front and rear)
oem r-line 5spd shift ****
peanut butter headliner, door cards, rear hatch.
vdo boost gauge
center steering wheel column pod
brand new ebrake console with armrest delete
brand new shifter console
suspension
b&g coilovers, dampening and height adjustable
neuspeed 28mm rear sway
notched frame for passeneger side, driver side, and tie rods.
wheels
ccw classics with arp bolts
fully polished
17x9 (2.5'' lips)
17x9.5 (3'' lips)
brand new falken ziex ze-512 tires (less than 1,000 miles)
205/45
215/45
as far as a prices goes, im looking for $14,000 obo
if you want the car without the ccw's $12,500 on steelies.
i am open to trades.
car is located in south florida.
aaand the bay that never got finished.
2002.5
103k
awp 20v 1.8t
atp hardware
tial 38mm wastegate
tial 50mm bov
IE rods
new rod bearings
transmission
5 speed
peliquin LSD
vr6 clutch
maintenance
exterior
reflex silver
filled hood notch
filled bumper notch
shaved side markers
shaved hatch
rear euro bumper
oem 20th headlights
interior
vdo boost gauge
suspension
wheels
fully polished
17x9 (2.5'' lips)
17x9.5 (3'' lips)
205/45
215/45
