B18C Starting Problem
Old Sep 11, 2009 | 07:19 AM
ForceDblock's Avatar
Default B18C Starting Problem
Hey guys have a problem starting my engine.Starter is new battery is new wiring is correct.Once it starts it runs great but the problem now is not starting. When i try to start it the dash lights turn on but when i turn the key all i get is a weird sound from the fuse box and main relay.My friend says it might be the main relay or the coil inside the distribuitor. PLEASE HELPppppppppp Thanks
Old Sep 11, 2009 | 07:21 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: B18C Starting Problem
the coil not battery in the dizzy can do that. try a new one
any check engine lights?
Old Sep 11, 2009 | 07:26 AM
yes the check engine light is on
Old Sep 11, 2009 | 07:27 AM
but only turns on after the car heats up
Old Sep 11, 2009 | 07:29 AM
I'm not Rick!
thats fine. when it comes on...check it.
i put a swtich on the 2 cel wires. when i need to check a light..i flip the switch
you need to know what code it is
Old Sep 11, 2009 | 07:52 AM
if i replace this for an external coil would it work without the internal coil?????
msd???
Old Sep 11, 2009 | 07:54 AM
and what about the sound coming from the main relay should i replace it????
I'm not Rick!
yes, i have one and those are super nice
Old Sep 11, 2009 | 08:00 AM
good thanks
Old Sep 13, 2009 | 05:11 PM
I FIXED MY PROBLEM IT WAS ENGINE GROUND THANKssssssssssss
Old Sep 13, 2009 | 05:13 PM
ALso have another question i just bought a msd blaster 2 with the ignition cover for a b18c, if i install this external coil do i have to take out the internal coil or i can use them both??????? im going turbo in a week???????
Old Sep 14, 2009 | 06:39 AM
I'm not Rick!
yes you have to take out the internal coil. i took mine out and soldered wires from the wires in the dizzy to the external coil and it workx nice.
fyi i made a bracket and hid my coil under the intake manifold
Old Sep 14, 2009 | 06:52 AM
S2Integra's Avatar
There is an issue with MSD caps becuase I used one for quite a while and then Car seemed like it didn't want to run. One day I stalled in the middle of an intersection in the turn lane. After days of troubleshooting, I put the stock cap back on and it fired right up. I think the MSD cap electrodes get spaced or they get covered in a substance nonconducive to electron flow. Never had a problem with any of the MSD coils though. Now I run a stock cap, msd rotor, and some autozone internal coil. Seems Fine!
Old Sep 14, 2009 | 06:53 AM
S2Integra's Avatar
How'd that Get loose?
Old Sep 18, 2009 | 04:16 AM
i only had one ground and it was the transmission and its painted so thats why there was no solid contact thankksssss
Old May 24, 2010 | 09:10 PM
B18B1-Crx's Avatar
Yea same thing happened to my bro. you have to use the msd rotor as well and keep it clean cause it has almost double the charge to create burnt electron dust crap. its common.
89pre2.0si
Jun 19, 2008 02:47 PM
EL Vap133
Apr 9, 2008 09:38 AM
Ej7-Safone
Jul 9, 2006 07:23 AM
Shambro84
Mar 25, 2004 04:48 PM
G2tegra
May 14, 2003 06:13 AM
