95 Accord ex Problems
Old Sep 11, 2009 | 05:40 AM
94trouble's Avatar
Default 95 Accord ex Problems
Ok so i have a 95 accord ex. It has a constant miss up untill 2,000 RPM anything above that and the car drives fine with no miss. I replaced the spark plugs and wires and i still have the miss. Its getting pretty bad MPG too. Any help is appreciated
Old Sep 11, 2009 | 09:38 AM
oblivion2kx's Avatar
Default Re: 95 Accord ex Problems
Check your timing and Check the cylinder compression, should be between 150 - 180 and it shouldnt be more than 10 off each one.
Old Sep 13, 2009 | 01:35 PM
94trouble's Avatar
Ok cool ill do that.
Also when im at a stop the brake pedal sinks in and the car begins to move. Ive bled the brakes several times and i still cant get a good pedal feel. Im guessing the booster took a crap on me? And when i bleed the brakes i only get a couple of drips of fluid from the rear bleeders. The fronts come out just fine.
Old Sep 13, 2009 | 02:36 PM
ShadowWorkssimc's Avatar
It sounds like you have a vacuum leak on your manifold.
Old Sep 13, 2009 | 08:17 PM
tommyboy042281's Avatar
your brake problem is the master cylinder. brand new from napa is 80 bucks or 40 bucks from autozone rebuilt. i just changed mine cuz i had the same problem. brakes work beautiful now.
Old Sep 17, 2009 | 05:49 PM
miller9779's Avatar
yup
Old Sep 17, 2009 | 09:32 PM
HONDAPARTSMANMIKE's Avatar
i would rec checking operation of egr and cleaning the egr ports
thebobrusso
Suspension & Brakes
Jun 8, 2009 10:57 AM
lilo_goki
Sep 12, 2007 06:27 PM
Rhood
Mar 13, 2007 10:24 AM
jayjay
Jun 26, 2006 03:42 AM
wra10s
Aug 31, 2001 06:22 AM
