Signs of a Distributor going bad?
Old Sep 10, 2009 | 10:44 PM
95_Civic_4dr's Avatar
Default Signs of a Distributor going bad?
Sorry if this seems obvious or whatever but I'm still learning...
'95 ex stock D16z6 Manual
Anyway, I noticed my RPMs will jump up an extra 500-800 when I'm going in full throttle past 4,000 RPM. The gauge will rise smoothly and just suddenly jump up and start going crazy for a second or two not matching to the actual engine speed. Second, I noticed when at night, with the increased electrical load (because of the headlights/dash lights) the car will idle rougher and every minute or two the rpms will jump from 600 to 900-1000, before doing this the car will shake and make a rough vibrating noise. Same will also happen at times when I press the brakes (With lights on). The battery is holding at 12.50v and while the engines running it holds at 14.17v, I'm pretty sure it's not the alternator as well. All I can think of is the Dizzy but I don't want to replace it just yet if anyone else has an idea, I may also get it tested at AutoZone tomorrow as well.
Any inputs please, thanks.
Edit: I forgot to mention, the car seems to run unusually weak with the AC on.
Old Sep 10, 2009 | 11:08 PM
D16SiHatch's Avatar
Default Re: Signs of a Distributor going bad?
well the rpm gauge going crazy is a pretty good sign in itself that the dizzy is going bad. i dunno if i could say for sure that the distributor is the problem, but i certainly wouldn't be suprised if that was the case.
Old Sep 10, 2009 | 11:43 PM
Hope it's not the Dizzy but it's all I can think of...more $ to spend
Anyone know an at home test I may be able to do on the Dizzy? Maybe a link? All I can find for the last 30min are useless info from Google and bad guides.
Edit: Could it be the IAC Valve? Maybe it's just dirty or clogged up a bit. The problems mainly occur during idle, but I guess that wouldn't explain the RPMs jumping while in VTEC.
Old Sep 11, 2009 | 11:20 AM
D16SiHatch's Avatar
i can get you an igniter test to try out. since its an intermittent issue though, i dunno if this test will necessarily tell you anythings wrong.. worth a shot though i guess.
Old Sep 11, 2009 | 12:56 PM
Flint707's Avatar
When my dizzy was going bad... it wouldn't let me rev the car past 3500 rpm's.
Old May 3, 2015 | 11:44 AM
Fallriverb16's Avatar
exact same thing with my dizzy no rev past 3500rpm
Old May 3, 2015 | 12:01 PM
White_EG1's Avatar
plz no bumpy of old threads
XGlite015
Jun 13, 2013 08:55 PM
iCollectStraws
11
Jan 7, 2009 09:12 AM
919DumpedCD5
Sep 24, 2008 06:56 AM
corym
Nov 7, 2006 09:24 PM
dmxsoulja3
12
Dec 24, 2004 11:55 AM
