D15 Bogging at full throttle. Help?
Old Sep 10, 2009 | 08:08 PM
si del sol 94's Avatar
Default D15 Bogging at full throttle. Help?
When i have the throttle open half way it takes off normally, if i open it all the way up it bogs out. Can anyone help me out?
Old Sep 10, 2009 | 09:11 PM
lponcian5799's Avatar
Default Re: D15 Bogging at full throttle. Help?
Check your IACV. There may be some carbon build-up inside your throttle body.
Old Sep 10, 2009 | 09:39 PM
boxeocampeon's Avatar
Or it could be misfire. whens the last time you changed your plugs and wires?
Old Sep 11, 2009 | 02:43 PM
Just changed the plugs about an hour ago and its still bogging. As for the iacv im going to check it. i will get back to you. Thanks
Old Sep 11, 2009 | 03:39 PM
ninjasruleyou's Avatar
well if its bogging at full throttle, it kinda sounds like a fuel problem, your sucking in the air but not getting enough fuel......maybe check the fuel filter to see if its flowing ok....im going to have to ponder on this one
Old Sep 11, 2009 | 04:32 PM
could be a clogged fuel injector or maybe it needs a valve adjustment
Old Sep 11, 2009 | 07:28 PM
1FDUPCIVIC's Avatar
If at all possible, check the voltage at the throttle sensor, should be around .6v at closed throttle and around 4.6v at WOT. It does sound a lot like a fuel problem, though. If for the throttle sensor voltage stays low, it oculd effect the amount of pulse width being commanded by the ecu.
Old Sep 11, 2009 | 07:51 PM
nicefighter80's Avatar
map sensor also would explain why its boggin at WOT check your map
Old Sep 11, 2009 | 10:51 PM
earlylocks's Avatar
make sure your car is not misfiring!
Old Sep 11, 2009 | 11:37 PM
thats what i thought it could be misfire. did you change the wires when you changed the plugs? it could also be the ignition coil
Old Sep 12, 2009 | 05:28 PM
EG2Vtec's Avatar
Maybe it's because it's a D15? Incurably slow, sorry to burst your bubble.
Old Sep 12, 2009 | 05:34 PM
92eg_h22's Avatar
You wasted your first post dude....don't be a gayfer...this kid is asking for help and you wanna clown on the motor???? tsk tsk tsk
Old Sep 12, 2009 | 07:21 PM
Jimster480's Avatar
Wow not a good way to get on HT with that. D15 is slow. Pls.
You need to check your TPS because this is what happened when my TPS went. You have to get a Meter and test what the voltage is @ Idle and @ WOT.
Old Sep 12, 2009 | 08:07 PM
sde780's Avatar
I have a D15, who gives a flying **** what motor he has.
When my cam timing was off I would bog up hills when I gave it more than 1/2 gas.
Old Sep 13, 2009 | 05:53 AM
yeah, you might want to make sure your timing didn't just a tooth......that would be a good place to start......
Old Sep 15, 2009 | 08:46 PM
I finally have a day off tomorrow so I'm going to try he suggestions. I have a friend who has a spare fuel pump if that the problem. The wires are arching a bit so that's another thing I'm going to have to get in the morning. I appreciate every ones input a lot. thanks and I will get back to everyone on Thursday.
Old Sep 15, 2009 | 08:48 PM
oh yeah and buy the way i got a ls im building and a turbo kit if that's an ok motor for ya..
Old Sep 15, 2009 | 09:02 PM
Jimster480's Avatar
So your going to do a LS on boost?
Old Sep 16, 2009 | 07:39 PM
yeah but that's not for a little while. I have bills to pay like everyone else haha. gotta make sure the d15 is gunna be able to be my daily for a little longer. by the way my buddy and me checked the duel filter and the ws some build up but still some bogg but help.. thanks
Michael Noriega
Dec 22, 2016 10:20 AM
BIGef
Jul 22, 2013 10:01 AM
silverdcteg
May 16, 2011 07:30 AM
19_hatch_93
Nov 23, 2008 07:08 PM
Goldfingiz
Jul 22, 2003 01:26 PM
