D16A--No spark, no fuel pump prime--checked main relay and srchd!!
Old Sep 10, 2009 | 08:04 PM
Coltmorris's Avatar
Default D16A--No spark, no fuel pump prime--checked main relay and srchd!!
So the motor wont turn over, I pulled off the cap and my diz rotor apparently flew off, destroying the contact points on the cap and the rotor itself. Slapped on a brand new cap and rotor, and I still have no spark--I have not yet checked the ignitor (should I?) Now, when I key on the car I do not hear the fuel pump prime, switched out my main relay--I hear it click on but again, no fuel pump prime that I can hear--I have yet to do a fuel pressure check. This happened as I was driving I stepped on the throttle and it just fell flat. Could these problems be related? Any ideas would be much appreciated--Im going to further diag my spark issue tomorrow Thanks!
Old Sep 10, 2009 | 08:10 PM
Joel.'s Avatar
I C U P
Default Re: D16A--No spark, no fuel pump prime--checked main relay and srchd!!
In for an answer. I just swapped a Z6 into my beater that hasn't moved in like 2 years and I'm having the same problems (no spark, no fuel prime).
Old Sep 11, 2009 | 05:17 AM
dephtone's Avatar
Check the fuse under the dash for fuse #14 Alternator Solenoid valve. This powers things like the main relay, which also powers the distributor and the fuel pump. I would check there first. Also check the ECU fuse under the hood to see if maybe that is broke also.
Old Sep 11, 2009 | 06:10 AM
Coltmorris's Avatar
Just checked fuse 14, its fine. Im so confused. Is it possible that me cranking the car again and again could have burned out my fuel pump? I was stranded in the city trying to get somewhere, so when I was first trying to start it I wasnt listening for the pump.
Old Sep 11, 2009 | 07:14 AM
dephtone's Avatar
Did you check the ECU fuse under the hood?
Old Sep 11, 2009 | 09:16 AM
Lamchop0000's Avatar
low on gas? thermostat ground in place?
Old Sep 11, 2009 | 10:46 AM
Coltmorris's Avatar
Ok so, what I failed to mention was that when trying to bolt everything back up, I put my battery in backwards (tard)..This blew the 60A main which I replaced...what I didnt realize was that my underhood ecu fuse was indeed blown. As well as the ECU! I popped in a spare ecu I had and it runs. Thanks for all the suggestions. One thing does lead to another!
Old Sep 11, 2009 | 12:51 PM
Joel.'s Avatar
I C U P
Glad you got it figured out. Mine actually started up too, the main relay was just stuck
Scarekrow
Oct 11, 2015 08:05 PM
4drint3gr4
43
Sep 10, 2009 02:07 PM
jstafase
Jun 15, 2009 09:15 PM
zcmotor
30
Mar 17, 2008 05:53 PM
1QwIkEf
Jan 10, 2005 08:15 PM
