Anyone ever done b18a bottom,ls rods,ctr pistons,b16 head combo on a stock ecu?
I was wondering if anyone on here has had this setup running any oem ecu (ie-CTR,ITR,JDMR,etc),I am running a stock bottom b18a,ls rods(arp bolts),CTR pistons,and a b16 head(no shave)so about 11.8:1 comp,and also how high are you reving,where does power band end?
ya plenty have melted pistons.
CTR pistons are ****, and shouldn't be used anything that isn't a b16..
There's a whole list of reason why ctr pistons are garbage but i'll give you two..
Their heavy.. and they **** up the flame on the combustion process, they spread it too thin and the process is all flubbed because of it.. there's more reason , i dont feel like given them tho
your CR wont be around 11.8.
More like high 13's with a OEM 3layer HG only reving to 8k.
makes sense, the flame front cant reach out across the top of the piston is what your saying?
see I calculated the CR before and I thought it would be that high, then I just checked it on cspeeds comp calc the other day said 12:3 with b16 piston to deck and 11.9 with ls piston-deck height. what piston do you recommend?
CTR would NOT be the piston I'd choose....for hardly anything
Stock computer....HELL NO. Those timing maps wouldn't even be CLOSE
Sean @ ESG
Oct 16, 2007 09:24 AM
fast4imports
Apr 12, 2007 06:30 PM
stdefhatch
Oct 3, 2005 05:55 PM
