[HELP]99-00 ek ebay fog light wiring problem.
well i bought one of those ebay fog light sets and i cant find the place in the fuse box under the dash board to plug in the harness from the fog light. it even looks like there isnt even a spot where the harness would fit. anyone have an idea why? any help is good. thanks.
this is how i wired the lights up.
that brown colored wire plugs into the acc. hole in the fuse box under the dash... <a href="http://photobucket.com/images/00%20ek%20under%20dash%20fuse%20box" target="_blank"><img src="http://i81.photobucket.com/albums/j230/Mike34655/1998AcuraIntegraGSR124.jpg" border="0" alt="00 ek under dash fuse box Pictures, Images and Photos"/></a>
its the second row from the top to the bottom... the fourth hole from the left to the right... hope it helps.
*** THIS ONE SHOULD WORK*** that brown colored wire plugs into the acc. hole in the fuse box under the dash...
I'll toss this out there too. It'll help you choose which socket to put the brown plug in. Some people have put it in the constant 12v one so they can flip their fogs on anytime. Others put it in Accessory power so they won't ever have to worry about forgetting to turn them off. This tells you what's what.
WAUKEENEM1
Mar 13, 2022 03:05 AM
LS94tegra
Sep 25, 2009 08:15 PM
enot767
Feb 27, 2009 02:23 AM
