MFactory Forged Gears - THE SPORTSMAN RACER'S CHOICE IN PERFORMANCE GEARS!
Hello Honda-Tech,
Close Ratio Gears - Street Series
Achieve the ultimate in acceleration with the MFactory Close Ratio Gears. Diamond Cut to exacting tolerances from fully Carburized Forged Nickel-Chromoly Steel and put through our own proprietary heat treatment process, you will not find a stronger, more reliable product on the market. Our special treatment process makes our gears several times stronger & tougher than OEM Gears and are specifically designed to endure the demanding requirements of high-power track/drag cars.
- Made from imported Japanese Steel
- Forged and Cryo-Tempered for unsurpassed toughness
- Advanced Shot Peening technology increases surface hardness
- Advanced gear geometry designed using industry-leading software puts more power to the ground
After installing our gears, you will experience a phenomenal increase in acceleration despite a lower top speed. Click here to see how much power you could gain!
Fitments:
Honda B16A/16B/18C:
3rd - 1.625 or 1.695
4th - 1.296 or 1.384 (Slight modification may be required to transmission casing when installing 1.384)
5th - 1.000 or 1.130 or 1.210 (Slight modification may be required to transmission casing when installing 1.130 and 1.210)
MSRP:
Choice of 3rd, 4th or 5th - $369.95 + Shipping
Choice of 3rd/4th - $659.95 + Shipping
Choice of 3rd/4th/5th - $799.95 + Shipping
Honda D15/16:
1st - 3.083 (Fits Cable & Hydro)
2nd - Re-use OEM 2nd gear
3rd - 1.565
4th - 1.250 (Re-use OEM 3rd Gear)
5th - 1.000
MSRP:
1st - $264.95 + Shipping
Choice of 3rd or 5th - $369.95 + Shipping
3rd/5th - $649.95 + Shipping
Honda L13/15 FIT/Jazz:
3rd - 1.285
4th - 1.030
5th - 0.886
MSRP: $799.95 + Shipping
Close Ratio Gears - Road/Race Series
Our new Honda B-Series Road/Race Series incorporate our advanced straight-cut design for increased performance and durability.
Fitments:
Honda B16A/16B/18C:
1st - 3.070 (Semi-Helical)
3rd - 1.636, 1.670 or 1.704
4th - 1.313, 1.355 or 1.387 (Slight modification may be required to transmission casing when installing 1.355 and 1.387)
5th - 1.028, 1.118 or 1.210 (Slight modification may be required to transmission casing when installing 1.118 and 1.210)
MSRP:
Honda K20A:
1st Gear - 2.313 (Semi-Helical)
2nd Gear - 1.650 (Semi-Helical)
3rd Gear - 1.304 (Semi-Helical)
4th Gear - 1.080 (Semi-Helical)
5th Gear - 0.958 (Semi-Helical)
6th Gear - 0.851 (Semi-Helical)
MSRP: $2499.95 + Shipping
RECOMMENDED SYNCHROS: When ordering your MFactory Close Ratio Gears, we highly recommend that you order our Carbon-Moly Synchros at the same time. By utilizing a carbon/molybdenum coating technology, which acts as braking material during gear engagement, this allows for quicker and more precise shifting. This also prolongs the life of your new synchronous gearset. Available for Honda B16A2/16B/18C, D15/16 & H22A in 3rd, 4th & 5th Gears. CLICK HERE for more information.
Final Drive Gears
Just like our close ratio gears, the MFactory final drive gears are also cut from the same high quality fully Carburized Forged Nickel-Chromoly Steel while also benefiting from our proprietary heat treatment process. As a result, we are proud to offer enthusiasts the best final drive gears on the market today.
By changing your final gear ratios, you can experience a dramatic increase in acceleration, giving you on average, a 10-15% increase in torque throughout the entire rev-range over the OEM Final Drive. CLICK HERE to see how much power you could gain!
Honda B16A2 Fitments: Will not fit models equipped with Factory LSD
Honda B16A2 and B18C 4.923: Offering a revised design over our previous generation 4.928 Final Drive Gears. Forged from stronger steel with a 50% larger tooth profile yet almost 1kg lighter!
Honda Cable Fitments: Will not fit models equipped with Factory LSD. 92-93 YS1 transmissions should use B16A2 fitments
Honda '98 Spec Fitments: Designed for the '98 Spec Integra Type-R with Factory 4.785 Final Drive
Honda H22A Fitments: Will not fit ATTS-equipped transmissions. Is also suitable for Euro-R/Accord Type-R
Fitments:
B16A Cable (Non-oem LSD) - 4.928
B16A2 Hydro (Non-oem LSD) - 4.0, 4.267, 4.71, 4.923
B16B/18C - 4.0, 4.267, 4.71, 4.923
B18C JDM '98 Spec - 4.0, 4.267, 4.71, 4.923
D15/16 - 4.5, 4.7, 4.9
H22A/F20B - 4.64, 5.15
L15 FIT - 4.47, 4.687
K20/24 - 5.08, 5.46, 5.84, 6.33
S2000 - 3.90, 4.40, 4.57
MSRP: From $564.95 + Shipping
Take your performance to the next level with the MFactory PRO Series Gears. Recognizing the demand for transmission components that can withstand the extreme shock loads produced during Drag Racing, MFactory Competition Products are proud to offer our range of top-tier competition level gears.
Diamond Cut to exacting tolerances from Forged High-Nickel-Chromium-Molybdenum Steel and put through our own proprietary heat treatment process, the MFactory PRO Series Gears are the pinnacle of off-the-shelf performance gears for today's Sport Compact.
Through the use of leading-edge Solidworks 3D CAD & Cosmos FEA software, our advanced gear geometry helps to increase tooth strength, reduce friction and, most importantly, minimize parasitic drivetrain losses. Transmissions built with MFactory PRO Series Gears transfer, on average, 1-2% more power to the ground over our competitors!
- State-of-the-art Wide Peen Cleaning; significantly more advanced than regular "Shot Peening", and used by several F1 and Le Mans teams
- Proprietary Ti-Moly Coating increases surface hardness, increases thermal resistance and lowers friction
- Designed to withstand the extreme shock loads of competition-level Drag Racing
PRO Dog Gear Sets
Our premier transmission upgrade, the MFactory PRO Series Dog Gear Sets includes our newly redesigned Shafts & Gears, increasing drivetrain efficiency and virtually eliminating Axial Shock Loads. Please note that Dog Engagement is not recommended for use on the Street.
B16A/16B/18C Set Includes:
1st Gear - 2.818
2nd Gear - 1.769
3rd Gear - 1.250
4th Gear - 0.910
Final Drive - 4.850
Shaft Brace
MSRP: $4499.95 + Shipping. ETA 1-2 Months
K20 Set Includes:
MSRP: $3999.95 + Shipping. In Stock and Ready to Ship
PRO Synchro Gear Sets
As requested by our large number of drag racing customers, we are proud to offer our PRO Series Gear Set, designed to withstand high-horsepower boosted applications! A highly recommended upgrade for those running 500hp+.
By keeping our gears synchronous engagement, our gears are a direct swap for your oem gears with no further parts required for installation and, unlike a dog transmission, are suitable for a daily driver.
Available for B-Series and H-Series.
Fitments:
1st - 2.786 (Straight Cut)
2nd - 1.900 (Straight Cut)
3rd - 1.430 (Straight Cut)
4th - 1.100 (Straight Cut)
MSRP:
1st/2nd (includes Mainshaft) - $1599.95 + Shipping
3rd/4th - $1499.95 + Shipping
1st/2nd/3rd/4th (includes Mainshaft) - $2999.95 + Shipping
PRO Final Drive Gears
Whether used standalone or alongside our PRO Series Gear Sets, our redesigned PRO Series Final Drive Gears increase drivetrain efficiency and are the final link to fine-tuning your race transmission.
Fitments:
K20/24 - 5.08, 5.46
S2000 - 3.90, 4.44, 4.57
MSRP: $899.95 + Shipping
B-Series 5th Gear Shaft Brace
Help keep your high-horsepower transmission together with the MFactory Shaft Brace.
By keeping your transmissions shafts locked together (but still able to spin freely as intended), our Shaft Brace helps counteract the effects of Radial Loads created from highly loaded gears.
Our Shaft Brace is particularly recommended for those running straight-cut gears in their high horsepower transmission due to the increased Radial Loads created (an inherent weakness of straight-cut gears).
- Only the highest quality Japanese Bearings used
- Helps reduce shaft separation caused by Radial Loads
- A must for all high-horsepower drag cars
MSRP: $199.95 + Shipping
<---------- IMPORTANT NOTICE ---------->
We have recently become aware of cheap and inferior "copies" of our Final Drives & Close Ratio Gear Sets, including our own custom ratios, being made available on the market. These DO NOT go through the same forging and heat treatment processes and will compromise your safety if installed on your vehicle. STAY SAFE and only purchase your Final Drives & Close Ratio Gears Sets from an Authorized MFactory Dealer
To order online and pay via PayPal, please click here: www.teamMFactory.com
Fitments:
Honda B16A/16B/18C:
MSRP:
Honda D15/16:
3rd - 1.565
5th - 1.000
MSRP:
3rd - 1.285
4th - 1.030
5th - 0.886
Fitments:
Honda B16A/16B/18C:
MSRP:
Honda K20A:
Final Drive Gears
Fitments:
PRO Dog Gear Sets
1st Gear - 2.818
2nd Gear - 1.769
3rd Gear - 1.250
4th Gear - 0.910
Final Drive - 4.850
Shaft Brace
K20 Set Includes:
Fitments:
MSRP:
Fitments:
K20/24 - 5.08, 5.46
Okay so maybe you could give me some advise. I am currently working on building up my 1993 Integra. I am keeping the stock power plant (B18A) and would like to keep my tranny (YS1). My suspension is fully built from a Full-Race traction bar, LCA's, coilovers, and all new bushings. My motor will built bored and sleeved and run at 9.8:1 CR. But this is far from a mild motor as all internals are being upgraded. Now here in lies my issue. I will be running NA for the first year or so untill I can afford a decent turbo kit. I know nothing when it comes to gearing. I would like to buy a set of gears that will work good for both appliications. Any advise?
If low boost, you would probably get away with using a similar setup to All Motor (e.g 4.785 or 4.928 Final Drive).
If high boost, then it would be a different path unfortunately.
With the higher power, you may need longer gearing, just depends on your overall setup and what is required.
FD is $549.95 + $22 Shipping
Helical LSD is $649.95 + $30 Shipping
Metal Plate LSD is $899.95 + $30 Shipping
is the pro series 1st gear 2.786 straight cut (for b16) include both 1st gear on main and counter shaft to achieve that ratio? can it be bought separately?(ie. just the 1st gear coz my current 1st gear is 3.070 Mfactory)
It consists of straight cut 1st & 2nd, mainshaft & countershaft. You cannot use them with any other gear, they must be used together as a set.
Any idea when K-series road race gear-set will be available?
Have any 5.0ish final drives for a K20? selling any different geared 5th & 6th?
The K-Series gear set is still be tested at the moment, no eta yet.
Yes, we have a 5.08 FD available.
I yhave a question on the pro gear sets if I wanted to replace all my stock gears with them 1-4 what would it cost me, and what all is included in this set.
1994 gsr s80
1994 gsr s80
Getting an error trying to PM you...
i have a b18c thats built for 600whp+ but i have it capped at 386whp due to a stock drivetrain. i dont want shorter gears since all it will do is spin, but i do want stronger gears and synchros. do you offer anything thats not a shorter gear? whats the difference between the metal plate lsd and helicoil?
i do street drive this.
thanks, doug
thanks, doug
sanman000719: Price for the full pro synchro gear set is $2999.95 + shipping. This includes a new mainshaft, 1st, 2nd, 3rd and 4th.
EG6 Love: Our pro synchro gear set is not too short, so should be suitable for your needs. For drag/street, I would recommend the Helical as it is maintenance free and designed to handle your power level. The Metal Plate LSD is more for circuit use.
do you offer a complete kit for the synchro gearset? ie. 1-4 gears and mainshaft. carbon/moly synchros, lsd, bearings and final drive? if so please let me know. its for a drag car that will occasionally see street duty. i want to have a transmission that will stand up to 600hp-800hp safely. thanks
Mike
Mike
NEW PRODUCT - IN STOCK & READY TO SHIP
