Auto trans 1st gear slipping?
Old Sep 9, 2009 | 08:46 PM
tpot90's Avatar
Default Auto trans 1st gear slipping?
My 6th gen 2.3 AT (with 102k) is starting to struggle deciding which gears to use from 1st to 2nd gear while slowing down then accelerating @ speeds around 10-15mph. If I accelerate hard in first gear, it will slip and over rev a little bit before it gets into 2nd. I can mostly avoid that problem by letting off the gas a little before it upshifts.
I am well-aware of the 6th automatic transmission failure rate, so I wont be suprised to hear if my trans is failing. *No blinking D4 light. But I've heard talk about "solenoid issues" that can cause these problems. Also, my automatic trans class instructor spoke about solenoid issues in Accords.
So I want to hear from HT what everyone thinks. If these solenoid problems could be solved, then it would save a lot of time & effort. How should I troubleshoot this problem?
Old Sep 9, 2009 | 09:18 PM
Sketch o5's Avatar
Default Re: Auto trans 1st gear slipping?
thats what mine was doing in my old 6g before the auto went. thank god i sold it before it blew up, hahaha.
Chriser0
24
May 16, 2013 06:49 PM
jgauge
Aug 24, 2011 10:06 AM
littledude56
Sep 20, 2009 06:54 AM
BlAuDe97
Jun 29, 2007 12:28 PM
DrZaius
Apr 24, 2005 06:53 PM
