90 hatch lsvtec swap questings
Old Sep 9, 2009 | 08:11 PM
uboostivtec's Avatar
Default 90 hatch lsvtec swap questings
so im swaping a lsvtec in my buddies hatch, non si,, so im confused.. so he has obd0 ecu and hes buying a si harness obd0... he needs to get the injector resistor box right?? i was wondering how id wire that in
Old Sep 9, 2009 | 08:41 PM
punkdown's Avatar
Default Re: 90 hatch lsvtec swap questings
Search brah, everything is covered here probably a dozen times. You should be able to find guides in the FAQ thread at the top of the page.
here: http://hondaswap.com/hybrid-ed-ef-da...crx-dx-243384/
Old Sep 10, 2009 | 09:00 AM
dephtone's Avatar
If the car is a non Si the SI engine harness will not work with a DX or STD underdash harness. The firewall plugs are not the same as the Si has a Cylinder Position Sensor in the harness and the DX and STD does not.
He needs to use the stock engine harness and convert the car to MPFI before he can swap the motor in or he has to replace the under dash harness with one from an Si model for the Si engine harness to plug into it.
Old Sep 10, 2009 | 09:17 AM
sh!ft's Avatar
Who the fack changed my title?!
ya id either convert the whole cars harness to si or just do what dephtone said to do
Old Sep 10, 2009 | 09:19 AM
Creator's Avatar
Resistor box depends solely on what injectors you decide to use most a/m or OBD0 require one. If your injectors are OBD1 then you don't need one. The car should have one on it now and the Si harness should accommodate one as well.You should just steal what you need off of the Si harness and stick with the original harness.
You have much more to cover then just the resistor box. You will also have to wire up the vtec and switch out the ECU to run vtec. You've got axles to worry about because std hubs won't fit the axles your going to need.
It's a big can of worms
Old Sep 10, 2009 | 09:29 AM
sh!ft's Avatar
only to those who cant fish properly lol.
Old Sep 10, 2009 | 10:12 AM
you guys are high,, ive definatly used a si harness on 2 std hatches and they pluggd in fine
BigbamaBen
Nov 6, 2011 01:50 PM
BlendedEM1
Feb 13, 2011 07:06 PM
knightsef-eg
20
Jan 2, 2009 01:51 PM
ZAKU
Nov 18, 2008 04:15 PM
crx-si
Sep 1, 2008 05:54 PM
