Electrical Issues: Alternator or Battery?
Old Sep 9, 2009 | 07:20 PM
Tommy_Gunns's Avatar
Icon6 Electrical Issues: Alternator or Battery?
Not sure if it's the alternator or battery that's wrong with my electrical system in my ITR. Noticed it over the weekend, the engine would barely be able to crank over.
Did some tests:
1. At idle, 14.2 volts across the battery
2. Car off, 12.4 volts across the battery
3. At idle, with headlights (high and low) on, interior fan on highest and stereo going. The voltage across the battery goes to 14 volts and drops slowly (never returning to 14 volts). If I rev the car, it goes to 14 volts.
What do you think? Do I need a new alternator?
Old Sep 10, 2009 | 03:55 AM
Petah's Avatar
Default Re: Electrical Issues: Alternator or Battery?
Battery, has this ever been replaced on your R? I had the exact sypmtoms and it was alll good once i replaced the battery.
Old Sep 10, 2009 | 08:03 AM
jdmscg's Avatar
No Sales Forums
Id load test the battery, CCA's may be low. Or check you connections at the terminals, they may be loose. But yeah def sounds like a battery not alternator.
Old Sep 10, 2009 | 08:54 PM
hksitr's Avatar
batter problem
Old Sep 11, 2009 | 12:10 AM
rzz's Avatar
rzz
try out a new battery first, if the problem is still here
it may be voltage regulator problem
if voltage regulator is burned, voltage meter would go over 14v execpt under braking w/ accesssories on
97_hatch
May 20, 2008 03:26 PM
Integ-boy
Nov 26, 2007 06:12 PM
Syndacate
Aug 14, 2007 05:10 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
Evan55
Oct 25, 2002 11:07 AM
