massive part stock for sale.
Old Sep 9, 2009 | 03:35 PM
AJxr's Avatar
Default massive part stock for sale.
i know most of this is junk but im trying to get it all gone without throwing it in the garbage.
cleaning out my tent which is FULL of random parts. i can deliver the big stuff in the northeast for some gas money.
located in dutchess county ny.
i have vouches. paypal, postal money order, or cash in person.
MAKE OFFERS
1. d16y8 #1, ~100k. rod knock, complete 5spd engine. will part out. $50 as it sits because the head is now sold. ran when pulled from my car but yeah... knocker. like i said will part ANYTHING off it.
water pump gone.
complete intake manifold gone.
complete head sold.
2. d16y8 #2. ~120k. i have not ran this engine but the previous owner was honest and said it smoked a little but ran fine. $150. will part head and block.
3. d15b7 #1, ~143k. threw a rod, hole in block. parting it out. or whole thing for $50
distributor gone.
4. d15b7 #2, ~150k. smoked at start up then ran fine. head has been removed but have all the parts. $50.
no distributor, water pump, or timing belt.
5. d16a6 shortblock. ~100k, sat for awhile out of the car and there is a little rust in cylinder 4. i had to break it free but it spins over fine, crank and rods look good. $75 obo
6. d16a6 head, from above short block. ~100k. complete. $60 shipped with legit a6 cam. distributor not included.
7. distributors.
-d16a6 MPFI obd0 distributor (pictured above) $45 shipped (needed for mpfi conversion!)
-d15b2 dpfi distributor, no coil, cap, or rotor. $20 shipped
-d15b2 dpfi distributor, complete. $30 shipped
-obd2 ls/b20 distributor. $45 shipped
8. JDM p75 head, came off 2000 jdm b20b. clean, low miles. $75 shipped complete with ls valve cover. has all matching cam caps, and the b20 cams.
9. 1995 b18b1 head, ~180k miles but ran great on engine, no smoke, no overheating. complete with all matching cam caps, ls valve cover, and ls cams. $60 shipped
10. cable d series transmissions.
1990 4spd STD manual transmission. worked fine $50
1988 DX 5spd trans, shifted like butter. $75
11. obd0 ecus
-5spd pm6 ecu $35 shipped
-b18a1 ecu $25 shipped
12. ef hatch climate control #1. uncracked, no broken parts. best offer
13. ef hatch climate control #2. uncracked, no broken parts. comes with cables. best offer.
14. b16a camshafts, comes with both cam gears, the one isnt pictured but i have it. $30 shipped
15. 1g and 2g dsm blow off valves, $20 shipped each. 1g is crushed.
16. cloth DA seats, black. some dust but very clean. $50
17. black cloth eg seats, came from a coupe. wierd fabric but its cool. small rip in driver seat as pictured. some dust but clean seats. $50
18. SOLD
19. SOLD
20. d16y8 intake manifold #2. $30 shipped
21. b20 valve cover, make your ls motor look sweet! $45 shipped
22. SOLD
23. SOLD
24. MISC turbo flanges.
t2 inlet flange, sr20 t25 compressor outlet flange, random 3 bolt flange, sr20 t25 exhaust outlet flange, 5bolt t3 exhaust flange.
$10 shipped each or $30 shipped for ALL. all have gaskets except the t3 5bolt flange.
cant fit anymore in the other thread so here goes round 2!
1. HF manifold, go boost cheap! $30 shipped
2.
3 sets of ls rods/pistons. $30 shipped per set
1 set of d16a6 rods and pistons $30 shipped
d16y8 upper timing cover, $10 shipped
d15b7 upper timing cover, $10 shipped
3. outer tail lights for 92-95 civic 4 door $30 shipped for both
4.
complete d15b7 intake manifold $40 shipped
d16z6 throttle body #1 good tps $25 shipped
d16z6 throttle body #2 no tps $20 shipped
5.
b series flywheel, $20 shipped
89 civic d series flywheel $20 shipped
2x coilover sleeves $10 shipped for pair
d series power steering pump, from 93 civic idk what else it will fit $20 shipped
2x stock shifters, $10 shipped each
gsr dual bend shifter, modified to fit sohc shift linkage, with 4spd shift **** $20 shipped
97 civic dx 5spd ecu, $20 shipped
3x b series oem cam gears, $10 shipped each
2x sohc oem cam gears, 88-95, $10 shipped each
3 of the outer cam caps for a dohc vtec b series head, $20 shipped
6.
to much in this picture to list, make offers, ask questions
the gauge is an autometer VOLTS gauge, $20 shipped for that.
7. stock injectors
$10 shipped a set
1 set of obd0 with plugs
X amount of obd1 240cc injectors
1 set of 2002 civic si injectors iwth clips $20 shipped
8. 3" cutout $25 shipped
9. timing covers, $10 shipped each (different then the ones above)
1x y8, 1x z6, 1x d15b7
10. external wastegate
works but as you can see the dummy before me ground down the bottom part of the wastegate so a parts wastegate will come with it and an extra 10psi spring. you can make one good wastegate out of these parts. $30 shipped
11. good condition fuel sender for 88-91 civic/crx $30 shipped
12. misc fuel rails, $10 shipped each
13. great condition trunk release cable for 92-95 civic 4 door $20 shipped
14. misc motor mounts. not sure what is what $10 shipped each, 3 for 20 shipped
15. valve covers $28 shipped a piece
16. starters $22 shipped a piece, i have a total of 8, 2 arent pictured and are the same as the 2 on the left in the pic below
17. valves for an air bag setup, suspension stuff. idk what they are or what they do but they came with a bag kit i got with a nissan pickup i bought a few years ago. $25 shipped for all 4
18. acura center caps $15 shipped for the set
19. 88-91 hatch driver headlight $30 shipped, has small imperfection
20. 88-91 passenger headlight $30 shipped
21. FAZE air/fuel gauge $20 shipped, does not come with pod.
22. clusters
90-93 integra cluster $30 shipped
88-91 automatic cluster $20 shipped
23. monster t4 turbo, good center section. cold side was stolen for a t3 t4 setup. comes with what you see. $25 shipped
24. intake manifolds
b18a1 intake mani $35 shipped
b18b1 intake mani $35 shipped
polished b18b1 intake manifold $35 shipped
Old Sep 9, 2009 | 04:17 PM
daluv's Avatar
Default Re: massive part stock for sale.
Bump!
Old Sep 9, 2009 | 07:24 PM
blackeg's Avatar
man you got lotsa parts!
Old Sep 10, 2009 | 07:15 AM
92egvx's Avatar
dam...interested in the #1 d16y8 but no cash right now...but its just a knock like spun bearing...let me know thanks...
Old Sep 10, 2009 | 11:59 AM
AJxr's Avatar
knock from a spun bearing but it didnt throw the rod yet.
Old Sep 10, 2009 | 08:15 PM
scottso990's Avatar
where in NY r u located
Old Sep 11, 2009 | 02:17 AM
AJxr's Avatar
dutchess county
Old Sep 11, 2009 | 09:04 PM
DatatRex's Avatar
would you ship the 88 dx transmission?
Old Sep 12, 2009 | 01:07 PM
AJxr's Avatar
yes but shipping is going to be rediculous. as much as id like to sell it id reccomend you search local.
Old Sep 12, 2009 | 01:11 PM
AJxr's Avatar
bump just added MORE PARTS!
will continue to update as time goes on.
Old Sep 14, 2009 | 02:22 AM
AJxr's Avatar
bump, y8#1 head sold!
Old Sep 19, 2009 | 04:58 PM
AJxr's Avatar
bump for a crap load of new parts!
AssemblyX
Nov 24, 2010 08:16 AM
eastbay92cx
Apr 7, 2008 02:10 PM
speedehatch
Jun 16, 2003 05:51 AM
