wow can my life get any worst?? :( plz help me!!!!
Old Sep 9, 2009 | 03:01 PM
fcbdolphinz's Avatar
Icon2 wow can my life get any worst?? :( plz help me!!!!
hmm i just want to know sometin... my car just started leakin reallyyyyy bad... hmm i think is the tranny... hmm diz is the place were its leakin from.. the red circle in the pik....engine is a f22b2 if it help.. i think i know d answer but just making sure
Old Sep 9, 2009 | 03:10 PM
racingcrx's Avatar
Default Re: wow can my life get any worst?? :( plz help me!!!!
do you speak english? or know how to type the english language for that matter?
the picture doesn't help much either.
Old Sep 9, 2009 | 03:21 PM
wow go **** your self bro.. no lie if u was here.... u would be the first person i kill in my life.. cuz am so mad right now .. and u talkin all diz **** dont help out at all....for real... **** uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
Old Sep 9, 2009 | 03:22 PM
GhostAccord's Avatar
What is it leaking, black, brown, green or red?
It's kind of hard to tell where the leak might be coming from. The entire lower front of the engine looks to have oil on it. The part you have circled is the bell housing for the transmission. If I had to guess given the location you specified. I would say that it is more than likely the rear crankshaft oil seal. If you take the engine and trans apart you might be able to see better.
With the engine out of your car. Now would be an opportune time to replace all of your seals and gaskets.
Old Sep 9, 2009 | 03:24 PM
phootbag's Avatar
You took the engine out to check a leak?
Old Sep 9, 2009 | 03:27 PM
hmm dats not the engine .. i 4got to mention dat .. am sorry.. am just so mad right now dat am not even thinkin.. hmmm i took dat pik from the internet and i circled the spot form were the leak was commin.. i saw it from under my car... hmm the leak was hmm kinda brownnish red......i was drivin and i just park the car and i just heard diz sound.. and wen i look around hmm like right on the screws i guess of the tranny and the engine.. hmm it was leakin like alottt.. and i turn the car bak on and hmm it started to leak again.. and den i just shut it off....
Old Sep 9, 2009 | 03:34 PM
TheMuffinMan's Avatar
He knows where you live!
Brownish red is probably transmission fluid however that point is near the bell housing which doesn't contain fluid.
Old Sep 9, 2009 | 03:36 PM
Reddish brown could be tarnished (I've heard that pennzoil turns reddish brown) engine oil. Red is definitely automatic trans fluid, is your car manual or automatic.
Have you checked the engine oil dipstick to see if your oil level is down? Without a picture of the leak it's hard to say where it's coming from. Best thing to do is clean up the oil that is there now and see if you can pin point the leak that way. There is a new product out that helps pin point oil leaks with the use of a florescent die and a black light. Can't remember the name off the top of my head though, sorry.
You are going to have to jack up your car and get under there to see exactly where it's coming from. It could be the oil pan
Old Sep 9, 2009 | 03:38 PM
i saw the leaking like right from the screws on the bottom....i guess is were the tranny come 2gether with the engine ?!!!?!!!!
Old Sep 9, 2009 | 03:40 PM
phootbag's Avatar
Probably a barfing rear main seal. As said, clean and inspect. Pics of YOUR leak would help.
Old Sep 9, 2009 | 03:49 PM
hmm i cant jack up the car.. i moved with my mom and i dont have any tools at all right now.. none ... so idk i guess i have to spend soem money with a mechanic.... and my car is manual... i just hope my tran is not completly mest up....and i hope i dont have to replace it cuz i dont d money to dat right now..
Old Sep 9, 2009 | 03:50 PM
BBallz24's Avatar
How about a closer picture of the engine and suspected area?
On a side note dat is not a word. If you at least try to sound educated and form semi-complete sentences you'll get more/better responses.
Old Sep 9, 2009 | 03:56 PM
racingcrx's Avatar
x12834753124761576246519243
Old Sep 9, 2009 | 04:02 PM
hmm ill try to put up a pik .... and am sorry .. is just that idk that is just the way i write...on the computer of course lol..!!! and on papers lmao that are not for skool lmao
Old Sep 9, 2009 | 04:08 PM
P_Adams's Avatar
Rear Main Seal (seals the crankshaft to the engine block)
P
Old Sep 9, 2009 | 04:13 PM
[QUOTE=P_Adams;39912187]Rear Main Seal (seals the crankshaft to the engine block)
P[/QUOTE
that might be the problem??
Old Sep 9, 2009 | 04:19 PM
fcm's Avatar
fcm
Old Fart
It can only be one of two things, either rear crank seal or transmission main shaft seal, blow either one of them and the oil will leak out about where you say it does.
You will need to get it up on jack stands or ramps to make sure it is not from maybe the back up light switch or other sensor and just running down to where you see it dripping off.
Either way you will have to at least pull the tranny, [unless it is a sensor/switch] to see which seal it is, tranny or engine.
What is the MM&Y of car and what trim level? 94
Old Sep 9, 2009 | 04:25 PM
P_Adams's Avatar
[quote=fcbdolphinz;39912258]
P[/QUOTE
Most definitely.
Within that space between the engine and the transmission, there aren't many choices when it comes to leaking components.
On the engine = Rear Main Seal
On the Transmission
Automatic = Converter Front Pump Seal
Manual = Input Shaft Seal
The problem when you start discussing the Manual Trans Input Shaft Seal is that it's non-pressurized, and unless the transmission is grossly overfilled you won't leak there.
External leaks (valve cover, oil separator etc) can show up here too, but they would be obvious since they are ...... external
P
P
Old Sep 9, 2009 | 04:28 PM
hmm now that you say it might be a sensor.. hmm are they located on top?? like top left?? right on top of the tranny? because when i heard the noise that it was leaking i heard like a bubble sound like it was bubbling and it was from on top of the engine on the left side.. and then i saw the big leaking on the bottom but i was so mad at the moment i wasn't even thinking! and also i could see like water spray in the side i told u about... like right on top of the tranny....on the left side of the engine.... am sorry if i cant explain my self.. i don't have that much experience with cars .. sorry...
Old Sep 9, 2009 | 04:33 PM
[QUOTE=P_Adams;39912393]
Most definitely.
On the Transmission
P
P
hmm thank you.. you really help me out.. and am sorry if i dont write good lol because everyone seems to hate the way i write.. incomplete sentences lol...
Old Sep 9, 2009 | 05:05 PM
jdmwannabee's Avatar
the answer to your question is NO, your life cannot get any worst you posted a thread on honda-tech and now you're being ridiculed. that is the bottom.
Old Sep 9, 2009 | 05:09 PM
lmao that is funny lol.. u made me laugh and **** am havin a **** up day so props to u!!! lol....
but damn why is everyone such *** in here?/ what am i doing to you all ?!? (((((((( am just asking for some help and trying to learn something... damnn
Old Sep 9, 2009 | 07:10 PM
P_Adams's Avatar
Ridiculed? Not by this respondent.
P
Old Sep 9, 2009 | 07:35 PM
phootbag's Avatar
Your life could get worse. You could be a jdmwannabee
Old Sep 10, 2009 | 07:44 AM
Brad_and_the_acc's Avatar
If you could take some pictures it would help most definitely.. Since I dont have much to go off of Ill place a decent guess on the rear main seal..
And anyway.. Not a single person has just outright bashed you man.. Typing with proper grammer and complete sentences is much more pleasent to read, and people are more opt to help you out..
Try an post up pics ASAP..
